1 - 20 of 31 Posts
So, the transmission saga continues.
I was running up until lately (not the best, with hard shifts from 2 to 3rd gear) but now when you shift in drive it won't engage the gear, the engine just rev's. But if i turn the car off for a minute then restart the gear engages??? Opened the floor shifter and spayed with contact cleaner. Opened the TCM under the glove box and sprayed with cleaner...NOTHING...I towed it to a reputable MB independent here in Toronto, he placed it on his super duper OBD reader computer and he says the transmission needs rebuilding. $2500 bucks...Gears are slipping. Conductor plate pulls no code only a generic gear implausible/gear slipping code p25XX??
WTF can it be? This seems more electronic then mechanical to me...Any thoughts??? Can it be the transmission oil pump? When I'm lucky to get it in drive mode there is a more than usual whining sound from the trans. Then i come to a stop sign, it falls back to first gear and then the problem happens, It won't engage the gear, i shut off the car, wait a minute, restart and then it drives until i stop again...When gear is not engaged and you rev, there is no whining sound....I'm ready to take a sledge hammer to this thing :)
help
I was running up until lately (not the best, with hard shifts from 2 to 3rd gear) but now when you shift in drive it won't engage the gear, the engine just rev's. But if i turn the car off for a minute then restart the gear engages??? Opened the floor shifter and spayed with contact cleaner. Opened the TCM under the glove box and sprayed with cleaner...NOTHING...I towed it to a reputable MB independent here in Toronto, he placed it on his super duper OBD reader computer and he says the transmission needs rebuilding. $2500 bucks...Gears are slipping. Conductor plate pulls no code only a generic gear implausible/gear shifting code p25XX??
WTF can it be? This seems more electronic then mechanical to me...Any thoughts??? Can it be the transmission oil pump? When in drive mode there is a more than usual whining sound from the trans. When gear is not engaged and you rev, there is no whining sound....I'm ready to take a sledge hammer to this thing 馃檪
help
Find a different mechanic. It needs a conductor plate.
Have you checked the fluid level?
Rudeney,
Your right, I bought the dip stick, it's low on fluid. Where did it go? I see no physical leaks on floor...
Do i specifically need the MB trans oil or can I use a Valvoline MAX LIFE ATF Dex/Merc' Mercon LV?
Also what are your thoughts on topping it up with LUCAS transmission fix?
thx jamie :smile
Check around the electrical connector on the transmission - it's a common place for leaks.
These are the approved fluids:
https://bevo.mercedes-benz.com/bevolisten/236.14_en.html
I would not us anything not on that list.
Thanks Rudeney,
They have the Fuchs Titan 4134 compatible oil from your list through Amazon.ca for $21 cnd 1lt or Germanparts.ca $13 cnd 1lt
https://www.amazon.ca/Mercedes-Transmission-FUCHS-Performance-4134/dp/B00KL4X3S6/ref=sr_1_2?keywords=FUCHS+TITAN+ATF+4134+Automatic+Transmission+Fluid&qid=1559410716&s=gateway&sr=8-2
I will add some and see what happens,
thx again
Jamie :)
Just make sure you put it in the correct tube:
I'm having issues with my spcoupe 2002.
Bought it a few months ago , and notice the car went in limp mode from time to time, had to pull over, kill the ignition, wait few seconds, restart engine, all fine...
Had the car diagnosed, don't know error codes, but he told me i have to replace electronic plate on transmission, and also told the problem would agravate, wich it did.
I'm working in France and had no time to adress the problem back then, so kept driving hoping it would hold till august , when i'd return and fix it.
Well at the moment i'm stuck in limp, already ordered parts, filter, joint, plate, atf, etc...
Today i read about atf climbing through the wires, took a look at the TCM, and though there ARE signs of oil in the wires and conector (left), i removed TCM , opened it gently, and inside is clean and dry, which leads me to believe either the leak is not very big and o-rings on the plate conector aren't that bad, or maybe the problem was adressed in the past...
The clip in the cap where you put in the oil is also broken...
Is there a cheap diagnostic tool, that is able to erase error codes after intervention?
The transm is a 722.699, the car shows 280k.
Thank you all in advance!
Icarsoft i980 or foxwell nt520.
Get a 722.6 dip stick. The intermittent limp home mode some times happens when ATF level is low.
Since you already have the TCM disassbled, reflow the row of large solder joints where the Plug pins go into the PCB. Those develow micro cracks over time which fill with ATF.
Use Valvoline Maxlife ATF. It's the only ATF to use with this transmission. The list is wrong.
I am not sure why you keep stating that. Is is because the 722.6 originally use 236.12 spec fluid? The 236.14 spec supersedes that. I'v used it in many, many 722.6. transmissions with many thousands (hundreds of thousands collectively) miles.
Maxlife is not on the 234.14 or 236.13 list. While it might be just fine, I tend to stick to what;s on t the approved list.
I ordered titan atf 4134 , which is recommended by MB and follows 236.14 norm , and as far as i read online is good atf for this transmission. Also waiting for dipstick, so i can check fluid level, i believe it can be low...
For the limp mode being intermittent, it was so in the past, but now it is permanently locked in limp, i was told by someone that to get it out of limp, the only way is to erase error codes after replacing the solenoid plate and fluid, so i have to wait for it to arrive, i ordered it from ebay , must be here this week...
I'm going to clean the best i can the wiring harness and plug (anyone know if thats something you can find online?)...
Many thanks to you all!...
Not sure about i810. I uses SDS, so I don't have any experience with iCarsoft, but based on other forum member's experiences, the i980 will reset codes in all the car's system. The more expensive MBII will as well, but other than a bigger screen, it has no additional features you'd need to pay extra for on a W203.
Will icarsoft I810 do the trick?
It seems to be much cheaper....
No. i810 only does generic OBD2. You need something that. Can talk to the Mercedes transmission computer. That means either i980 or MB2.
Use Maxlife ATF. It is the correct ATF for this transmission. Read the label on the back for more info.
Hi folks!
I just ordered icarsoft I980, a digital laser thermometer, and still waiting for conductor plate kit and dipstick...
It might sound noob, but thats exactly what it is 馃槢 but can anyone guide me through the menus to erase transmission codes?
What is the best video tutoring full diy procedure (i have watched a LOT...) and still i am not sure which process is easier and better for a full drain of the old atf (i watched it done by compressed air and also by aspiration through the filter opening).
What is your opinion based on your own experience?
I'm praying that all will be fine with the solenoids , once the obd2 arrives, i'll try to pull out codes, i hope the device needs no update out of the box, for i have no pc with me...
Once again thank you for your advices! 馃槉
First thing I would do is check and clear codes. Plenty of YouTube videos on how to use the icarsoft. Take it for a drive see how it behaves, recheck for codes. Once at operating temp check ATF level with engine running.
Is it true that you can only erase dtc from transmission by plugging into 38 pin plug under the hood?
Does that mean i have to buy an adaptor for the icarsoft I980?
Thanka!
1 - 20 of 31 Posts
