2002 Mercedes C320
I recently was experiencing battery drain issues and was in the process of troubleshooting the cause, as I was checking the fuses to see if maybe I was having a draw and to see if the some of the fuses were blown, after pulling and looking at the fuses i didnt notice anything. I went to start my car, everything was fine but my interior dome lights and the car charger port/cigarette lighter spot doesnt work? any idea what I did?
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
Hmm...if you've got a multimeter, try seeing if you're getting voltage. It's probable that you're not.
I would also check those fuses with a multimeter. Usually you can see if the fuse is blown. However, I've seen instances in which the fuse blew, but not in a way that was easily visible.
