E-350/2010 4-MATIC (E-320/2000 R.I.P.)
Error message popped up recently, no other issues so far, no ABS, only the above message and warning light. Not sure what’s causing this, Any suggestion?
Thanks in advance.
Besides scanning for codes... if it was a wheel speed sensor, then I imagine the ABS would be inop as well. No other issues? All controls on steering column work?
All controls on steering column working. Steering column was changed about a year ago because gear stick completely snapped in half when changing gears! (See image below) 😮😩 But no problems since then. Scanned for codes, but nothing. Scanner is a regular OBD scanner. Going to try to purchase a MB scanner from Icaresoft and see what I can pull.
