How To Remove Low-Beam Bulb -- 2013 GLK - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-01-2019, 12:40 PM Thread Starter
Date registered: Sep 2009
Vehicle: '91 Merc 190E 2.3
Question [SOLVED] How To Remove Low-Beam Bulb -- 2013 GLK
I own a 2013 GLK 350 with Halogen Lights. I'm trying to change out the lowbeam bulbs but i cant figure out how to remove them. The owner's manual is useless and there is no spring clip which everyone believes is the only thing Mercedes uses. Please have a look at the photos of the rear of my low-beam bulb.
Can you provide me a step by step on how to remove this as there is NO VIDEO in existence showing the removal of this type of fitting. I've already tried pressing down on the metal "tab" nearest the "y" of "Germany" but it doesnt budge; from all the squeaking if i press any harder it feels like i will break something. Pulling back on the black wire harness prongs only pulls the wire harness away from the bulb end -- it does not extract the bulb which remains solidly in place.
Thanks
quantass is offline
post #2 of 2 (permalink) Old 08-01-2019, 02:53 PM Thread Starter
SOLVED.
The trick for me was while using one hand i placed my thumb on top of the 12 o'clock silver tab and placed my forefinger below the wire harness against the silver backend of the bulb (the forefinger will be placed above the 4 o'clock and 7 o'clock silver tabs covering the label 12v 55w DOT 12972; the wire harness will still be attached). Next while pressing down on the 12 o'clock tab (more as a way to secure the entire assembly from moving) i then began pulling up with my forefinger at the 4 & 7 oclock position. This began freeing the bottom end of the bulb. I kept pitching this end until it cleared the 4 & 7 oclock tab friction. It shouldnt take all that much force or pain. I was then able to pull back on the bulb to pull it out of its housing. Once the bulb was out i noted which way the protruding edge / tooth was facing. That is the UP position. I then removed the bulb from the still attached wire harness.
When reinserting the bulb i oriented the new bulb so that its protruding edge was facing up like the old one then attached it to the wire harness. I inserted the bulb with the UP end pitched inward first allowing it to slide into the 12 oclock tab. I then pitched the other end of the bulb downward so that it snapped into the 4 & 7 oclock tabs. Very easy to reinsert.
quantass is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X204 GLK-Class
