Never ending P0410, P0171, P0174 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-09-2019, 10:13 AM Thread Starter
Date registered: Jan 2018
Quoted: 4 Post(s)
Ive had these codes for months now. I have replaced the MAF sensor, the secondary air pump, all the lines from the air pump to the check valves, and I've replaced both check valves. The codes keep coming back. Ive gotten a vacuum test to test for leaks and no leaks. Has anyone else had the same issue?
engineerjet is offline
post #2 of 8 (permalink) Old 06-09-2019, 11:45 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 878 Post(s)
For the money you have spent plying parts darts you could have bought complete turn key CF52 + MB Star C4 SD Connect + SSD.
https://www.aliexpress.com/item/CF52...AbTest=ae803_5
Is air pump running after cold start?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 8 (permalink) Old 06-09-2019, 12:13 PM Thread Starter
Quoted: 4 Post(s)
yes, the air pump runs.
post #4 of 8 (permalink) Old 06-09-2019, 12:33 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 878 Post(s)
Do you have vacuum pump with gauge?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #5 of 8 (permalink) Old 06-09-2019, 12:36 PM Thread Starter
Quoted: 4 Post(s)
i do not but i had this test run on it with no issues.
post #6 of 8 (permalink) Old 06-09-2019, 12:51 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 878 Post(s)
So, why is P0410 still there?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #7 of 8 (permalink) Old 06-09-2019, 04:29 PM Thread Starter
Quoted: 4 Post(s)
I have no idea
post #8 of 8 (permalink) Old 06-09-2019, 04:42 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 878 Post(s)
I have no idea
Go to the top of this forum and hit custom Google search with "P0410" Plenty of reading.
Please update your user profile with car and location info. If you are using mobile device look here. https://www.benzworld.org/forums/w16...l#post17015001
Order vacuum pump. https://www.amazon.com/MV8000-Automo...ateway&sr=8-43
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X204 GLK-Class
