Gauges stopped working - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-15-2019, 11:53 AM Thread Starter
Date registered: Sep 2018
Vehicle: 2008 B200 Turbo, 2010 GLK350 4Matic, 2010 R350 BlueTec 4Matic
Quoted: 2 Post(s)
Last week ESL in my 2010 GLK quit on me. I fixed it (replaced motor) but wheen I started the car, now gauges do not work: speedo is on 0, tach sits at 1000, temp is at 0, fuel shows 1/8. None of them move. Rest of the cluster work: all warning lights, ilumination lights, center info screen.
Hooked up MBll code reader. Have instrument cluster stored (only, not current) codes but can not clear them: P046164 (fuel level sensor range...), B210A84 & B210D16 (power supply low...)
Checked IC fuse, good. Took it out and put it in (re-powered IC), but nothing helps.
Any ideas what should I do next?
Derek66 is offline
post #2 of 3 (permalink) Old 02-16-2019, 09:20 AM Thread Starter
Quoted: 2 Post(s)
Couple of more questions:
Why would I be not able to clear stored faults?
If I get used instrument cluster, would it need to be programmed/coded? And if yes, will it work (gauges) before coding?
Derek66 is offline
post #3 of 3 (permalink) Old 02-18-2019, 02:48 PM Thread Starter
Quoted: 2 Post(s)
Solved.
Removed and reinserted all fuel system related fuses (7 of them). All back to normal. What a relief.
First code (fuel level sensor range..) pointed me in that direction.
I think I may know what triggered this ordeal.
When waiting for parts to fix ESL, with battery disconnected, I added 20l of fuel to the car. My thinking is that when battery was reconnected fuel gauge reading was not what "car" was expecting. When one at the time fuses were removed and reinserted something did reset itself. If that makes sense.
Derek66 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X204 GLK-Class
Mercedes GL450 - wipers, SRS, cigarette lighter and glove box light stopped working vladc77 X164 GL-Class 14 05-23-2016 09:05 AM
ML270 CDI AC and Instrument Cluster stopped working rjeans W163 M-Class 11 04-16-2015 05:47 PM
W220 Trunk Auto Close and Airmatic Seats stopped working abovne1 W220 S-Class 5 11-13-2013 01:46 AM
Gauges Not Working - Fuel Tank Sender Issue? gradyg3 W210 E-Class 7 04-16-2011 08:01 PM
Dash gauges stopped working schlitz100 R/C107 SL/SLC Class 8 12-27-2010 03:48 PM
