2013 GL 550 with original trans and diff fluids - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-31-2019, 12:33 PM Thread Starter
Date registered: Mar 2019
Hi All,
Visiting with friend who has 2013 5.5 GL ... 120,000 miles and has never changed transmission fluid. Nor differential fluids. She said local indie said not to change either.
Given the mileage, what is the recommended course of action ... I'm familiar with the argument regarding changing old fluid, but know the argument is simply that ...
Options: do nothing, flush/change, or partial change to avoid "fluid shock?"
My person opinion on the trans - limited background - is to pick a safe spot for her. Have indie drop pan and replace filter, replace that fluid. Then drain and replace fluid two more times. Gets new fluid, avoids rapid cleaning, and replaces the filter. If it was mine, I would drop the pan, see if it had a torque converter drain bolt and drain it as well.
Differentials and transfers are a different beast. I would probably drain and replace rear differential, for sure, but no real feel for the front and transfer case.
BTW - I had posted this in the wrong forum with the wrong date yesterday - trying to get it where it needs to be today. Sorry if any confusion.
Thoughts?
ForumUser1 is offline
post #2 of 5 (permalink) Old 04-02-2019, 12:20 PM Thread Starter
OK. Will hop back over the "other" forum.
BTW - it is actually the 4.7 with twin turbos, not an actual 5.5L V8.
post #3 of 5 (permalink) Old 04-05-2019, 05:41 AM
nhdblfan's Avatar
Date registered: Feb 2008
Vehicle: 2007 CLK 550,2014 ML 550
Quoted: 12 Post(s)
I have the 2014,ML 550-same engine 4.7 twin turbo.
I would to the front/rear dif and the t case,and trans.That I would do a couple more times till the fluid looked new. I would not flush the trans.I was a biz maanger of a tras shop and say many units replaced before a flush and after it dislodged material that was best left alone needed to be rebuilt.
If they skipped the driveline maintenance I would also do the engine oil,brake fluid and coolant just to start fresh
nhdblfan is offline
post #4 of 5 (permalink) Old 06-17-2019, 01:02 PM
Date registered: Mar 2007
Vehicle: 1997 E420
Quoted: 15 Post(s)
I think the fluid is now advised by MB to be changed at some point so I would follow that advice. I changed mine at about 120K I think. FLUID IS EXPENSIVE and I think your idea of changing it all 2 or 3 times seems excessive.
ca_tallguy is offline
post #5 of 5 (permalink) Old 07-22-2019, 08:59 PM
2000 C280 Sport's Avatar
Date registered: May 2008
Vehicle: Whatever car has the gas in it
Quoted: 76 Post(s)
Well that is on her then... If she feels comfortable doing that then go for it. I mean congrats she managed to save about $1,000 total from not changing the fluids. I am sure you can find a new tranny for under that price I would personally find a local shop to change the fluids and filter. Better safe then sorry. That is what I would do.
2000 C280 Sport is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X166 GL / GLS-Class
WANTED - W210 E55 or C43 with dead trans or diff visal911 For Sale/Wanted/Trade/Giveaway 0 04-07-2016 10:20 AM
Price check, Trans, Diff, Brake fluid flush/replace denial512 W211 E-Class 4 01-31-2014 08:00 PM
trans fluid and diff fluid replacement cost? numitor R170 SLK-Class 10 07-28-2007 09:40 PM
Is it the trans, diff, or flex discs? mgw_300e W124 E,CE,D,TD Class 10 09-13-2006 06:19 AM
Had my trans and diff fluids done today 176,968KM on the OD. Swizzles W163 M-Class 2 09-22-2004 05:32 PM
