Lomtevas's 2015 GL350 BTC - Page 15 - Mercedes-Benz Forum
post #141 of 144 (permalink) Old 03-14-2019, 06:00 AM
Date registered: Jun 2015
Originally Posted by joeboch348 View Post
You seem to be an expert. I have 2 questions for ya.
1) Tires. My tire guy came up with the original run flats or Michelins. I went with the Michelins for a smoother ride, but 40k miles later I need new tires. I wasn't happy with them either the edges get peeling off little chunks.
I went with Michelin Defender LTX M/S tires. They’re not the exact replacement size but I’m extremely pleased with them. See my comments under my tire post in this forum.
Todd
ctpj is offline
post #142 of 144 (permalink) Old 04-16-2019, 01:23 PM
Date registered: May 2014
Vehicle: 2015
Quoted: 5 Post(s)
Awesome post - wish U did videos of all these maintenance jobs. Mine 2015 GL350 just got out of warranty and I am trying to see if I can do some of those. Seem like MB is trying to make it hard for the owners to do so - even a simple task of finding parts number isnt that simple with that SUV. I couldnt find it in my manual anyway - thus extra Thanx to U.
Is there a consensus as far as where to buy parts for MB - look like Amazon carry a lot of those. Is that where U get yours?
Ajbolit is offline
post #143 of 144 (permalink) Old 05-04-2019, 04:42 PM Thread Starter
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3, 2014 CLA250 and 2015 GL350 BTC
Quoted: 56 Post(s)
Send a message via Skype™ to lomtevas
Check Engine Light at 84,180 Miles
In response to the previous question, I use only dealer provisioned parts as shown throughout this blog.
I discovered this check engine light this morning. I drove to a filling station to fill her up, and then I returned to do some troubleshooting.
I lifted off the plastic motor cover and commenced unplugging and replugging all the electrical connectors I could find. I restarted the motor and the check engine light was no longer on.
I went and retrieved my Xentry system with multiplexer. I ran a diagnostic and discovered that the diesel's soot particulate filter sensor had a malfunction. I also noted that the 360 Degree camera system has an internal fault (which I knew from before), and the audio system has a fault.
I cleared the faults and we'll see if they return.
ID:	2509758   Click image for larger version
ID:	2509760   Click image for larger version
The home of the two 201's.
lomtevas is offline
post #144 of 144 (permalink) Old Yesterday, 03:44 PM Thread Starter
lomtevas's Avatar
Quoted: 56 Post(s)
Check Engine Light at 84,514 Miles
The check engine light appeared again after 350 miles. I connected the Xentry system and again saw a soot particulate filter sensor failure. I then bought the three soot particulate filter sensors and await their arrival at the dealer's.
Then, suddenly, the check engine light went out, but the sensors will be replaced because Xentry alerted twice on the same problem.
ID:	2513362   Click image for larger version
ID:	2513364   Click image for larger version
ID:	2513366   Click image for larger version
ID:	2513368   Click image for larger version
lomtevas is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X166 GL / GLS-Class
