Spark Plugs Change - What should I watch out for? - Page 2 - Mercedes-Benz Forum
post #11 of 20 (permalink) Old 07-16-2019, 10:32 PM
Date registered: Jan 2018
Vehicle: 2011 GL450
I use NGK Iridium LKR7AIX in a 2011 GL450.
F1zzer is offline
post #12 of 20 (permalink) Old 07-17-2019, 07:32 AM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 193 Post(s)
I changed my transfer case fluid shortly after I purchased my GL in 2017. It was black. My independent said it had likely never been changed.
tonylinc likes this.
james.calton1 is online now
post #13 of 20 (permalink) Old 07-17-2019, 10:15 AM
tonylinc's Avatar
Date registered: Oct 2005
Vehicle: W163 ML320, W220 S500, R230 SL600TT, R170 SLK230, W140 S500, More
Quoted: 48 Post(s)
MBZ says the transfer case fluid is good for lifetime, what they mean by lifetime is that when it breaks it's lifetime is over and time to see them and guy a new mercedes. $$$$$ They said that about transmissions, as well, what a moronic statement to think that any transmission will never need service. Planned obsolete = Breakdown, Maintenance = Long lasting. Still better cars than most, one just needs to be smart about things and maintenance will make anything last longer!
raed_jan and ianrandom like this.
tonylinc is offline
post #14 of 20 (permalink) Old 07-21-2019, 09:09 PM Thread Starter
Date registered: Jul 2019
Vehicle: 2009 GL 450 4Matic
Quoted: 4 Post(s)
I just changed the front and rear differential fluid on my GL 450. Oil was close to black. Quite an easy job and I used Mobil 1 75W-90.
Az In Cali is offline
post #15 of 20 (permalink) Old 07-22-2019, 05:32 AM
tonylinc's Avatar
Quoted: 48 Post(s)
In a few days I am changing fluid in both differentials and both transfer cases and also the little air filter for the Airmatic, in my 2008 GL450.
tonylinc is offline
post #16 of 20 (permalink) Old 07-22-2019, 08:00 AM Thread Starter
Quoted: 4 Post(s)
You refer to both transfer cases. I thought there's only one. Where is the 2nd transfer case?
post #17 of 20 (permalink) Old 07-22-2019, 10:45 AM
Quoted: 193 Post(s)
Only one transfer case.
post #18 of 20 (permalink) Old 07-23-2019, 05:25 AM Thread Starter
Quoted: 4 Post(s)
Transmission Fluid Change - Balancing Car
I used my Quick Jack to lift the GL 450 while I change the transmission fluid. I need the transmission fluid pan to be level so I can take accurate measurement of the fluid.
Anybody ever used a Quick Jack? How did you level the car?
post #19 of 20 (permalink) Old 07-23-2019, 03:44 PM
tonylinc's Avatar
Quoted: 48 Post(s)
I asked two shops how much cost to change the fluid in the transfer cases, one said $89 each... the other said $95 and that to their knowledge, there was only one. I know for sure there are two differentials..
tonylinc is offline
post #20 of 20 (permalink) Old 07-23-2019, 04:24 PM Thread Starter
Quoted: 4 Post(s)
There are 2 differentials and one transfer case in the GL. I just changed the fluid in both differentials and I used Mobil 1 75W-90. Easiest job you could possibly handle by yourself - just 2 bolts.
The transfer is also simple - just 2 bolts and it uses transmission fluid. It's too simple to pay someone.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
