Need some confirmation of differential and transfer case fluids - Mercedes-Benz Forum
post #1 of 6 (permalink) Unread 06-13-2019, 05:30 AM Thread Starter
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 126 Post(s)
Before I order the fluids, I just want to get confirmation especially since the Mercedes 85W90 is expensive
To do the front and rear differentials, I will need Mercedes hypoid gear oil 85W90. From searching, I cannot find an alternative other than one other benzworlder who said he has used Mobil 1.
If there is an update on an alternative gear oil, please let me know. It looks like autohaus az has a liter for $37. I have to do this service on all the diffs on two Mercedes so it there is a cheaper source, please share.
For the transfer case, Noodles mentioned that Shell AFT 134 can be used. I just wanted to make sure this is still going to work. His post was from 5 years back
Thanks
Mike
Michael Pillay is online now
post #2 of 6 (permalink) Unread 06-13-2019, 05:35 AM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 189 Post(s)
For the transfer case it will be the same fluid thatís in your transmission. If you have the blue fluid the ATF 134FE can be used. The rear diff will use 75W85. The front will use 85W90. Liqui moly is at the appropriate approval levels and is pretty affordable.
james.calton1 is offline
post #3 of 6 (permalink) Unread 06-13-2019, 06:25 AM Thread Starter
Quoted: 126 Post(s)
Thanks James. I should have mentioned the GL450 is a 2007. I see your's is a 2012. I am assuming the fluids are the same for both model years.
Mike
post #4 of 6 (permalink) Unread 06-13-2019, 06:42 AM
Quoted: 189 Post(s)
Yes for the differentials. For the transfer case you will use the ATF 4134 red fluid MB 236.14.
post #5 of 6 (permalink) Unread 06-13-2019, 12:17 PM Thread Starter
Quoted: 126 Post(s)
Thanks again James. I will be doing the service in a couple days. I appreciate your help.
Mike
post #6 of 6 (permalink) Unread 06-13-2019, 12:18 PM
Quoted: 189 Post(s)
No problem glad to help. Itís pretty easy just drain and fill.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
