2008 GL450 Airmatic question - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-06-2019, 07:35 PM Thread Starter
Date registered: Mar 2014
Vehicle: 2004 clk320 2003 E320 2008gl450
Quoted: 15 Post(s)
Hi
I have 2008 GL450 with about 100k miles. I changed front air shocks and rear shocks and bags with arnott brand last august. At that time i also changed the fuse, relay and the pump. The pump was an off brand from Amazon but had good reviews. I did not change the valve block.
Recently i get the 5508 malfunction code saying i have a leak. The front of the truck is raised and holding pressure. The back looks slumped (evenly slumped) and rides rough. When i start the truck it does not sound like compressor is on.
My question is do you think this compressor is already shot? or could it be the valve block? Is there an easy way to tell either or?
I checked the relay and it is good as well as the fuse. If the compressor was bad wouldn't the rear bags still at least hold air? Also i see there might be a holding tank in the rear. Where is this located?
Thank You
dkasht is offline
post #2 of 8 (permalink) Old 07-04-2019, 09:01 PM
Date registered: Jul 2019
Vehicle: 2008 GL450
Right side rear air spring wonít inflate
Greetings! Just joined the forum and thank in advance for all the expert advice.
I have a 2008 GL450 with 50k miles. Recently it is leaning a little with right side low. Looked underneath, surprised to find that lower end of right side rear air spring is not seated in the mounting hole, it is just dangling freely to the side. I am guessing for some reason that air spring was not inflated when the car was on the lift for tire rotations a few month ago, the lower end of air spring might have got lifted out of place, so when car was lowered, the end of air spring just got pushed to the side.
In any case, I removed that air spring, checked it does not leak (hooked up to compressed air, no soap bubbles), installed it back on car again.
Turn the engine on, found that air spring is soft to the touch and doesnít inflate. Compressor appear to work since I can raise and lower front end of car, but back end always stays low. The left rear air spring is hard to the touch but seems just for residual air trapped inside. Fore I sis anything, left side wheel well was about 3-4 inch above the tire, now it stays at about 1 inch for both sides, but there is no warning message on dashboard.
Any advice is greatly appreciated.
post #3 of 8 (permalink) Old 07-06-2019, 03:22 PM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 193 Post(s)
Make sure the air line is tight going into that air spring. You also may want to spray both lines with soapy water to verify if they are leaking.
james.calton1 is online now
post #4 of 8 (permalink) Old 07-06-2019, 05:39 PM
Vehicle: 2009 GL 450 4Matic
Quoted: 4 Post(s)
I'm having similar issue. Where is the relay please?
Az In Cali is offline
post #5 of 8 (permalink) Old 07-06-2019, 05:41 PM
Quoted: 193 Post(s)
Itís in the fuse box located just to the left of the radiator when you open the hood.
post #6 of 8 (permalink) Old 07-06-2019, 05:49 PM
Quoted: 4 Post(s)
Thank you
post #7 of 8 (permalink) Old 07-06-2019, 05:54 PM
Quoted: 4 Post(s)
I hope this does not sound stupid. But is the relay, the black one beside the orange fuse?
post #8 of 8 (permalink) Old 07-06-2019, 07:29 PM
Vehicle: 2008 GL450
I found my problem was caused by valve block not distributing pressure to the back air springs. After replacing it, rear air spring work again, but it seems calibration is off and rear end is a little lower than the front.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
atmsmshr
