Cleaning engine with low pressure garden hose and degreaser - Mercedes-Benz Forum
post #1 of 2 (permalink) Unread 05-21-2019, 12:26 PM Thread Starter
Date registered: May 2019
Vehicle: 2009 GL450 SOLD / 2011 GL550 current daily
I want to clean up the very dirty engine bay on a 2011 GL550 I just purchased so it can be clean and so I can visually see any issues.
This is what I plan to do, are there any other suggestions for a GL550 specific engine?
- Run cold engine for a couple of minutes to warm up grease/oil/dirt on engine.
- Remove plastic cover and air filter housings.
- plug up exposed inlets from where air filter housings were removed.
- put plastic bag over alternator.
- put plastic bag over ECM
- Put plastic bag over MAF
- 1) Spray engine with degreaser.
- 2) scrub with brush.
- 3) hose down with low pressure water from garden house. Do not use pressure washer.
- repeat 1-3 if still dirty.
- blow off excess water with air compressor or use leaf blower if you don't have air compressor.
Reno Marcellus is offline
post #2 of 2 (permalink) Unread 05-22-2019, 03:43 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 135 Post(s)
And then get ready for problems .
This is a retro ride .
plinker17722 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
