Ecu technical question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-20-2019, 06:25 PM Thread Starter
Date registered: Aug 2017
Vehicle: 1990 300
I will make a long story short . I have a 2011 gl350 which began to throw a code , I had a guy come and he decided to attempt an ECU reset ( don’t ask me why ) and didn’t back up the original flash . My situation NOW is my car has no power anywhere including at the OBD port . No lights go on , the instrument cluster does not go on , the power locks do not work , the car is completely dead but the battery has a full charge- I even jumped it and that didn’t do anything. Has anyone had this issue and if so what was the solution ?
Power at the battery ? : yes
Anything electrical probed ? : no
fuses popped? : no
LTpro is offline
post #2 of 4 (permalink) Old 05-20-2019, 08:27 PM
Vegasbenztech777's Avatar
Date registered: Oct 2006
Vehicle: 2007 CL550
Quoted: 8 Post(s)
You actually need to go into details. Explain the reset he was trying to do. Did he just disconnect the battery? Or was he using a laptop with DAS? Better yet explain the whole thing and I will try to help. If you like PM me and we can talk on the phone. I can only offer my best advice that's it.
Vegasbenztech777 is offline
post #3 of 4 (permalink) Old 05-21-2019, 08:02 PM
Vehicle: 2007 CL550
Quoted: 8 Post(s)
I guess you figured out that it was the battery after all. They crack between cells and have full voltage but absolutely no cranking power. If you come back here let us know.
post #4 of 4 (permalink) Old 05-22-2019, 12:03 PM Thread Starter
Vehicle: 1990 300
Yes and no , I still have a few issues . Check your messages
LTpro is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
Hypoid gear oil Genuine spec 235.0 technical question slsamg General Mercedes-Benz 2 07-28-2014 07:42 PM
The Question of God by Steve Martin Nightbird Off-Topic 8 11-28-2010 01:41 PM
Technical question - OEM xenon retrofit roadsleeper W221 S-Class 9 11-26-2009 11:38 AM
President Bush authorized the leak MBZ300CD Off-Topic 79 04-10-2006 08:48 PM
hey JDBOWER : question about your Kleemann ECU upgrade bocobod W163 M-Class 2 05-20-2005 06:31 PM
