GL550 Repair Advice - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 04-11-2019, 03:04 PM Thread Starter
Date registered: Apr 2019
GL550 Repair Advice
Started noticing a chemical smell several months ago from my 2010 MB GL550 (77K Miles). Car as been well maintained, single owner.
A service place has suggested that the AC system is leaking both the gas refrigerant and oil… and we are likely smelling the oil.
He shares that MB builds the car around the system, and as a result access for repair and replacement is extremely difficult. Noting the entire dashboard must be taken out, etc… with cost estimates of 5K
Can this be so??? Is it possible the compressor is the core issue, and that it simply needs to be replaced? Is there a means of repairing rather than replacing the entire system?
Camp is offline
post #2 of 4 (permalink) Old 04-11-2019, 03:17 PM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 179 Post(s)
Honestly it depends on what is wrong with it. If it is leaking from the heater core or another component inside the dash then yes it will be expensive as you need to remove the dash to get to that. The compressor is not too hard to get to. I would have a good independent test the system and give you an exact breakdown of what they say needs to happen. Run the actual finding by us here on the forum for advice.
james.calton1 is offline
post #3 of 4 (permalink) Old 04-11-2019, 03:24 PM Thread Starter
Thank you.... Will definitely have another check on it, and come back. Deeply appreciated.
Camp is offline
post #4 of 4 (permalink) Old 04-11-2019, 03:35 PM
Quoted: 179 Post(s)
No problem at all. Please keep us posted.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
Need advice on repair option net1961 General Mercedes-Benz 5 04-04-2012 08:55 PM
Rust Repair Advice RoysVeggy W126 S,SE,SEC,SEL,SD,SDL Class 2 09-20-2010 07:26 AM
A/C Repair repair advice on a 1981 240D rodriguez.brenton W123 E,CE,D,CD,TD,TE Class 1 08-16-2010 01:23 PM
Considering doing transmission repair myself, need advice please! cbowma4 W140 S-Class 13 08-01-2009 01:21 PM
