2102 GL450 Air Suspension Issue - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-03-2017, 04:48 PM Thread Starter
Date registered: Sep 2017
Vehicle: 2012 GL450
Good Day,
I have a 2102 GL450 that blew the drivers side rear air bag. I decided since that one went the others were not far behind. So I would swapped out the whole system with a new compressor and new air springs all around. I used Arnott A-2575 air springs on the front and Arnott A-2596 air springs on the rear. Me and my buddy did the whole job in about 3.5 hours. We buttoned everything up mindful that when we lowered the vehicle we did so to normal ride height. We turned the key and the front did fine. Air springs inflated and stopped when they were supposed to. However, the rear did not budge. Got nothing. No inflation at all. Air springs are as the came out of the box. I know they are good. There are no leaks in the system. What am I missing? Is there a sensor somewhere that needs to be adjusted. I'd find it hard to believe that the ride height sensors in the rear are faulty. They worked fine before the replacements were installed. I gotta be missing something. Probably simple but I just don't know. Any help would be grateful!
Frank Halstead
[email protected]
Frank Halstead is offline
post #2 of 4 (permalink) Old 10-16-2017, 04:29 AM
Date registered: Jan 2013
Vehicle: 2012-X164-GL500 (Grand Edition), 2014-W212-E300, 2013-W204-C200, 2012-Volvo S40 SE, 1994-LandCruiser
Quoted: 6 Post(s)
It might be as simple as you forgot to connect the sensor. I did so one time on a Volvo after cleaning the throttle-body, I forgot to plug it in and the car would not start properly!
Hope this helps,
Good luck.
ModySLR is offline
post #3 of 4 (permalink) Old 10-17-2017, 02:50 PM
Date registered: Jan 2017
Vehicle: 2007 GL 450
Hope this helps,
Good luck.
My guess would be the sensor also.
abtabor6 is offline
post #4 of 4 (permalink) Old 07-30-2019, 04:46 PM
Date registered: Oct 2015
Vehicle: 2006 ML500, 2009 GL450
Quoted: 7 Post(s)
I realize I am replying to an old post, but I appear to have the same issue. Any closure to this issue? Was it the level sensor that was the issue??
additive is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
