One door won't lock/unlock - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-18-2011, 12:21 PM Thread Starter
Date registered: Aug 2010
Vehicle: GL450
The door at the back of the driver side won't lock or unlock when pressing the black button on the handle. Other doors work, only this one doesn't.
What do you think is the problem? The handle itself?
jbayabas is offline
post #2 of 10 (permalink) Old 03-24-2011, 01:11 PM
Date registered: Jun 2009
Same exact thing happened to our GL350 a few months back. Dealer discovered the electronic module in the handle was faulty. They replaced the handle with a new one and it works great. Hopefully your is still under warranty.
wolfman064 is offline
post #3 of 10 (permalink) Old Today, 01:59 AM
Ancient Warrior's Avatar
Date registered: Dec 2016
Vehicle: GL450 CDI, 2010
Send a message via AIM to Ancient Warrior
This must be for a Keyless go system - correct?
Ancient Warrior is online now
post #4 of 10 (permalink) Old Today, 02:02 AM
Left front door wont open or lock the rest will. The problem is from within the vehicle and with key, no sound from the one door. Other 3 doors work perfect.
Removed the lock to look inside, spring ok.
What could that be.
post #5 of 10 (permalink) Old Today, 03:06 AM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 189 Post(s)
It could still be your door lock actuator. If you pulled the door panel and it doesnít move at all when the others do then thatís likely the culprit.
james.calton1 is online now
post #6 of 10 (permalink) Old Today, 03:32 AM
It is the nature of the beast, it does not move.
That would be the whole actuator it self, for e.g. A1647201535, correct?
post #7 of 10 (permalink) Old Today, 03:33 AM
Quoted: 189 Post(s)
Just make sure if you have keyless go you get the correct one. It will be the whole actuator.
post #8 of 10 (permalink) Old Today, 03:41 AM
Unfortunately, Not Keyless go, just ordinary wireless key operated.
A used one on ebay might not be a bad idea. Let me try that and revert.
Thank you so much for your help.
post #9 of 10 (permalink) Old Today, 03:46 AM
Quoted: 189 Post(s)
There is always a rush with a used door lock actuator. It may go bad quick.
post #10 of 10 (permalink) Old Today, 04:34 AM
I will take your advice and get a new one. Thanks
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > X164 GL-Class
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
Ancient Warrior
sl 500 door lock unlock lukess R230 SL-Class 12 09-10-2010 09:08 PM
Can't Lock/Unlock Door edong W140 S-Class 2 06-09-2010 12:52 PM
Door wont lock or unlock ///S320 W140 S-Class 1 12-26-2006 11:16 PM
300SD door lock issue (can't lock with key, but can unlock) Mugsy90/10 W126 S,SE,SEC,SEL,SD,SDL Class 5 11-12-2006 06:12 PM
Door Lock & Unlock dixiebenz R171 SLK-Class 13 03-27-2006 06:16 AM
