Glow plugs control unit pins - 5cyl OM602 engine - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-11-2019, 11:28 AM Thread Starter
Date registered: Nov 2018
Hello! I need to change my glow plug control unit relay for my 5cyl, 2.9 OM602 engine. I already have one, but I'm not sure if I should try to connect it because of the different configuration of my smaller jack that goes on it - it has only 4 cables and the relay has 5 pins (50, 31, 15, LA, and a "T") - check attached image - I'm not sure what is the purpose of that connection in general, if somebody could explain, I would appreciate it
I saw on many online stores, that there are two types - one with 4 pins and one with 5 pins. But the distribution of the "main" 4 ones is the same (50, 31, 15, LA) - the other one has another pin with a "T" letter. I'm thinking that maybe I can connect the one I already have and leave out the 5th pin ("T") - anybody has any idea what is the T pin for? I was thinking that maybe someone around here knows if it would work to leave the 5th one out.
Thank you!
BoBtheBoB is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-906 Sprinter
5cyl OM602 engine staring on only 4 glow plugs BoBtheBoB Diesel Discussion 4 12-17-2018 02:08 AM
We Need A Permanent Sticky for Error Codes Hary Gahtoe C208/A208 CLK-Class 22 01-22-2010 12:11 PM
Check engine light e320 cc238 W210 E-Class 16 06-26-2009 05:47 AM
Cam Oilers and Sludge Removal 97e420sweet W210 E-Class 14 01-14-2009 08:58 AM
Error Codes A Plenty.... TheOgre W163 M-Class 2 01-18-2006 06:52 PM
