sprinter 903 4x4 front differential bearing preload.. - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-25-2019, 05:02 AM Thread Starter
Date registered: Jan 2019
Vehicle: 2001 sprinter 311cdi 4x4 and 1999 sprinter 312d 4x4 and 1988 507d
Hi from new member
Has anybody got an up to date copy of WIS they are willing to check for me (or has anyone rebuilt the front drive on a 2001 sprinter 311cdi 4x4.)
Vin No..... Wdb 903 662 2R3 17542
WIS document AR33.30-D-8610-O2A* has info on bearing preload...... the problem I am having is
the differential tube has a bearing on each end of the tube that the differential is mounted in.... The mercedes WIS (2014 copy) I have says to assemble the unit with no shims behind bearing, measure end float with dial gauge then do maths by subtracting 0.15mm to arrive at shim thickness required,....*
This is straight forward and if done correctly will set up the bearings with 0.15mm end float.
I have done this and the shaft rotates freely with very little drag BUT
the next instruction says to use a torque gauge to measure the resistance to rotation of the differential tube and that it should be between 3 to 5 NM
If the shims etc. are fitted as per first part of instruction the rotational torque is zero in effect.
If* 0.15mm* IS ADDED* to endfloat measurement RATHER THAN SUBTRACTED with no shims then the bearings will be preloaded and the torque may be close to 3 to 5NM
With a 0.05mm pinch on the bearings I am getting a torque figure on the shaft of* about 1.0 NM ..
the outer casing the differential tube runs in is aluminium the differential tube is steel therefore different rates of expansion... do i preload the bearings ? If so do I preload the bearings by enough to create torque of 3 to 5NM which seems a lot?
thanks for any help mark
marktinkerman is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-906 Sprinter
Front wheel bearing on a C300 4Matic [email protected] W204 C-Class 1 09-10-2016 05:57 AM
Decoding ML datacards (what all those option codes mean!) stingray.au W163 M-Class 10 09-01-2016 10:30 AM
Bad Differential Bearing MB220D300D W140 S-Class 12 06-18-2012 03:52 PM
2007 c230 sport front wheel bearing replacement Boomerman44 W204 C-Class 1 05-21-2012 07:24 AM
Differential bearing replacement RohsWeee W201 190-Class 7 03-26-2009 08:32 AM
