2008 sprinter 315 cuts out while driving then starts again after a few mins - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-18-2019, 03:53 PM Thread Starter
Date registered: Jan 2019
hi all , i have a 2008 315 sprinter having a problem when i drive the van there is a slight hesitation , then it will just die out, then if i try start straight away it wont start, how ever if it sits 5mins then it will start then will drive for another while , will start hesitating again , the fault codes are
P0261 cyc 1 injector circuit low
P0264 cyc 2 injector circuit low
P0267 cyc 3 injector circuit low
P0270 cyc 4 injector circuit low
p1955 manufacture specific
i have cleared the faults then drove the vehicle then when it happened again i checked the codes and the same codes have came back!
ive wiggled the wire harnness as was told they can give trouble, but it didn't cut out so do i assume this is ok, was told it could be crank sensor or even the glow plug relay but is the injectors on the same circuit ?
thanks for your help
markyni104 is offline
post #2 of 2 (permalink) Old 01-18-2019, 06:08 PM
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 272 Post(s)
I had a recent experience with my Ď08 ML320. 120K miles that experienced failure to start when hot.
Iíve replaced the crankshaft position sensor which seems to have cured the problem.
YMMV
Sent from my iPad using Tapatalk
Skippy,
SkippyJasper is online now
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-906 Sprinter
