fuel leaking from high pressure pump - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 02-10-2009, 09:10 PM
Date registered: Jan 2007
Thanks for the response. Do you have the phone number or web address for this Cheltenham Diesel?
kenr is offline
post #12 of 13 (permalink) Old 11-08-2012, 09:43 AM
Date registered: Oct 2012
Vehicle: Mercedes Sprinter 311 CDI
Hi all. I know this is a long shot as this was posted so long ago, but any help would be great.
rifletech, or anyone else that has had this problem. What are the symptoms of this problem.
What warning lights come on on the dash board?
Does the speed of the van reduce and go into limp mode?
Does the van ECU register any faults, if so what error codes did you get relating to the problem?
Is acceleration uneven and not smooth like it should be?
I'm having a problem at the moment and suspect its the same or a similar problem and as the weather gets colder its getting worse.
Any help would be ace.
Kind regards
Andy
andy1981 is offline
post #13 of 13 (permalink) Old 09-01-2015, 05:30 PM
Date registered: Sep 2015
Hi,
I have sprinter 2004 302 Mwb, fuel pump was leaking a lot. I bought the seal kit and mechanic open the pump and put the seal in, now it's not leaking but now engine not turning on just cranking. the mechanic also replaced fuel tank sending unit, he think might be air regulation issue, the mechanic also put diesel manuallt into fuel regulator, but still engine not turning on just cranking,
Any advice from anyone
Hafiz is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-906 Sprinter
leaking fuel lines at pump junction? rotormotor W124 E,CE,D,TD Class 1 01-04-2007 08:49 PM
fuel air mix / testing fuel pumps and pump pressure william.wood W126 S,SE,SEC,SEL,SD,SDL Class 0 11-09-2005 11:32 AM
leaking hand pump vs fuel pump benzmeover W123 E,CE,D,CD,TD,TE Class 4 01-30-2005 07:36 PM
Fuel Pump Pressure Guest (MBNZ) General Mercedes-Benz 3 07-15-2000 03:34 AM
Fuel Pump Pressure Guest (MBNZ) R/C107 SL/SLC Class 3 07-15-2000 03:34 AM
