Problem with sprintshift box - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 10-30-2013, 03:59 AM
Date registered: Oct 2013
Vehicle: 304 and some other
Originally Posted by DBTRANSPORT View Post
Success all fixed, took dealer 4 days not the quoted 2 but had allready pinned them down to a price of 10hrs @ £60/hr. The parts that had failed/worn out were the first and second sincro's, bulk rings and selector dogs. All the parts together cost £314 and the labour was £600 so £914+VAT and all done.
If any one wants more info ie part numbers or pics of the parts let me know.
Hey,
We have the same problem now in our sprinter, so have you number of parts somewhere?
thx.
leppis is offline
post #12 of 16 (permalink) Old 01-24-2014, 08:47 AM
Date registered: Jan 2014
Vehicle: 2003 Sprinter 211 CDI
MB Sprinter 211 CDI
I have a problem with a 2003 Sprinter 211 CDI. It is a semi automatic which means that when I engage from neutral to automatic it is supposed to display letter A in the cluster. However it only shows first gear. I tried to drive it and I can only shift gears manually since the automatic does not engage. Moreover I can only do this up to the third gear. After this it wont go shift to the 4th , 5th or 6th.
Reverse function shifts clean, the first 3 gears shift clean (manually) also. Any ideas please? It would be great of a help!
Thank you!
sorinvlaicu is offline
post #13 of 16 (permalink) Old 05-08-2014, 02:28 PM
Date registered: May 2014
Vehicle: 2005
Thank you!
Sounds like the Clutch travel sender (G162) has failed which causes the following:
• Gearbox emergency mode will be activated.
• Gear changes in manual mode are then only possible up to 3rd gear.
• An “F” appears in instrument gear indicator.
See Page 56 of this document: http://www.volkspage.net/technik/ssp/ssp/SSP_372.pdf
Its worth studying this document as it really does explain just about everything that goes wrong with this gearbox.
(Its a VW document, but same sprint shift gearbox was used in both Sprinter & Crafter).
mikeyp69 is offline
post #14 of 16 (permalink) Old 05-09-2014, 06:10 AM
Exclamation MB 211 CDI
Problem turned out to be a faulty breaker that triggered the gearbox in the emergency mode. Which was a huge release for me. As for the other issue mentioned I will look into that.
Thanks Mike once again and have a great weekend ahead!
post #15 of 16 (permalink) Old 09-15-2014, 11:50 AM
Date registered: Sep 2014
hi there I had this problem turn ignition switch on up until start but don't start take out fuses 3 and 8 turn ignition off replace the fuses and start this sorted mine out this is a merc dealer trick good luck
dave bailey is offline
post #16 of 16 (permalink) Old 01-10-2015, 08:19 PM
Date registered: Jan 2015
Daz
Hi everybody, I'm looking to buy a Mercedes sprinter 2005 - 2006 model. It is a 5 speed automatic. I'm told it's a proper auto, not the peselect manual/ auto.
It's the 316cdi mob model. Can anybody tell me whether there are any problems with this model.?
Thanks heaps, Daz
Dazaus is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W901-906 Sprinter
sprintshift - sprinter johnaruba W901-906 Sprinter 2 08-19-2009 03:49 AM
problem with steering box phatkat W140 S-Class 8 10-27-2008 09:48 AM
Steering box problem broncoisl G-Class 8 03-16-2008 02:21 PM
Please help...Gear Box Problem Nawaid W201 190-Class 5 12-01-2003 04:12 AM
Auto Box Problem Russ280 G-Class 19 10-15-2003 06:46 AM
