2007 R350 Spark plug change - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-21-2019, 03:10 PM Thread Starter
Date registered: May 2015
Angry 2007 R350 Spark plug change
I would like to save a couple hundered dollars on changing my spark plugs in a 2007 R350. But i cant see the plugs for all the plastic housing cover. I assume they are located somewhere under this plastic. Am I correct and how do i go by accessing these plugs to change them. Is their a video or can someone help me in this
cowboysfanokc is offline
post #2 of 7 (permalink) Old 04-21-2019, 03:46 PM
Date registered: Mar 2019
Vehicle: 2003 ml500, 2004 ml350
Quoted: 50 Post(s)
You nee to pull the appearance cover off, carefully it is held on by spring clips. Doing my ml500 plugs as i am typing this popped in to check on what to torque them to.
wallyo is offline
post #3 of 7 (permalink) Old 04-22-2019, 10:28 AM
IWantedaJag's Avatar
Date registered: Jan 2014
Vehicle: 2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Quoted: 2531 Post(s)
^ Finger tight plus a quarter turn.
"Semper In excretio, solum profundum variat" - unknown
They called me mad, and I called them mad, and damn them, they outvoted me" - Nathaniel Lee
IWantedaJag is offline
post #4 of 7 (permalink) Old 04-22-2019, 03:56 PM
Quoted: 50 Post(s)
Found the torque specs they are actually in the owners manual. Another member posted that it was , can’t remember who it was to give them credit.
Any way went with 20 ft# kinda glad, some of them were a little stiff going in and were tough to Get by hand past the first few full turns. Got it done.
wallyo is offline
post #5 of 7 (permalink) Old 04-25-2019, 08:15 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 5 Post(s)
There are individual coils attached to each sparkplug. You'll need a TORX bit to remove them. Be careful not to break the locking tab when disconnecting the wiring.
The plugs are especially deep set into the cylinder head. Good to inspect with light for dirt in the cavity and to be able to blow any out before removing the plug. Useful to find specialty lubricant to grease the rubber boots a little bit.
It's a bit fiddly to get the air cleaner remounted ... if it doesn't seal as designed around the MAF sensor, you'll get a check engine light.
Kent Christensen
Albuquerque
'07 GL320CDI, '10 CL550
lkchris is offline
post #6 of 7 (permalink) Old 05-02-2019, 06:56 PM Thread Starter
Are you aware of any video i can view to change these spark plugs. I have a few pieces of plastic appearance cover on as well as some kind of bar that looks like it need to be removed ALSO..
post #7 of 7 (permalink) Old 05-04-2019, 10:23 AM
Quoted: 50 Post(s)
Here is a 2 minute video hope it helps.
You should blow or vac out the spark plug wells, before removing the plugs if there is a grain of sand and it falls in the cylinder bad things can happen. You can use canned air.
wallyo is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
DIY: Replace Spark Plugs Ickdeep W204 C-Class 6 11-03-2015 06:23 PM
When to change spark plugs? 2001 S500 shinbo W220 S-Class 22 01-15-2015 07:06 AM
Photo Diy- Spark Plug Change. G-AMG W210 E-Class 74 03-12-2014 06:51 PM
Spark Plugs and Transmission Fluid Change on SLK320 all in one place! blackslk320 R170 SLK-Class 11 03-31-2013 02:21 PM
CEL after spark plug change kabdulla W163 M-Class 8 12-08-2004 04:01 PM
