Rear cargo cover blind - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-16-2019, 01:37 PM Thread Starter
Date registered: Feb 2015
I have a 2007 R500. Can anyone tell me if this is the right cargo cover blind, or if it is missing parts? It fits very loosely in place and the "pegs" are not wide enough to engage within the slots to hold the cover extended.
ID:	2496826   Click image for larger version
ID:	2496828   Click image for larger version
novaguy81 is offline
post #2 of 3 (permalink) Old 03-17-2019, 08:10 PM
Lioninstreet's Avatar
Date registered: Jun 2014
Vehicle: '06 SLK55 P30, '12 R350 P2
Quoted: 4 Post(s)
Doesn't look correct. My current R doesn't have the blind, but my last one did. It fit snugly.
Lioninstreet is offline
post #3 of 3 (permalink) Old 05-13-2019, 11:35 AM
Date registered: Dec 2016
Vehicle: 2002 ML500;2007 R63
Just saw this.
There are two positions for the cargo blind. One with the 3rd row up (near the rear hatch) and one with the 3rd row down (just behind the second row). The opening you show in the first pic is where the blind gets attached. Hard to tell what you are showing in the remaining pics.
The blind has one side that retracts slightly with a button on the top. It is spring loaded. That is what allows for the snug fit.
It also has a plastic "extension" on each side attached by a single string. The extension mounts by putting it on; line it up 45 degrees from top straight up and lightly twist it so the extension lines up. Pretty self explanatory when you have it in your hands.
The extension is used when the blind is just behind the 2nd row; when behind the 3rd row, the extensions come off.
Regards,
Jerry
gsfent1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
In need of G500 rear cargo cover (black) gfcctx G-Class 0 05-10-2013 04:01 PM
Ml320 Tan (Java) Rear Cargo Cover For Sale bobalvis W163 M-Class 2 12-02-2006 09:38 AM
PHOTO OF YOUR CAR WITH VIN DECODER 93 BENZ S400SEL General Mercedes-Benz 36 02-12-2006 11:18 AM
rear cargo cover 06ml500 W164 M-Class 5 12-20-2005 05:42 PM
Valve cover gasket replacement – 95 E320. 71Rcode W124 E,CE,D,TD Class 0 03-10-2004 05:50 PM
