Lost power/boost - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-07-2019, 01:10 PM Thread Starter
Date registered: Mar 2019
Vehicle: 2008 R320 CDI
Lost power/boost
Hello
Would like to know if someone experience similar situation or can tell where to start diagnostics. Have my 98 R320CDI only for few months and kind of like it )
Car starts and idle fine when on Parking and accelerator is press rpm goes up no problem but when driving does not want to downshift gears stays less then 2000rpm and it takes a while to get to the speed (80km)
when I use paddle shifters there is no problem with shifting or RPM.
Engine light on
Thanks
Martin
ID:	2494682   Click image for larger version
ID:	2494684   Click image for larger version
baca240 is offline
post #2 of 2 (permalink) Old 05-18-2019, 07:24 PM
Date registered: May 2019
Almost same problem here
I had to replace the diesel particulate filter (the main catalytic converter that's visible). It was breaking up inside. I found a replacement on Ebay. But the main problem came from an exhaust port that was directly in front of the tension pulley. Somehow the tension pulley made a whole in that port and was losing air/boost/pressure. My expected $3,000 job turned into around $1100, which included labor.
Mike Mosley is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Vintage Images of a Lost Age: A Photographic Tour of 19th Century Germany Teutone Off-Topic 5 01-24-2013 06:44 AM
Lost Tribe Scams alchemy Off-Topic 4 12-15-2012 10:04 AM
Oktoberfest in Numbers Wedding Rings Lost, More Brawls Found Teutone Off-Topic 1 10-08-2012 03:26 PM
The World from Berlin 'Without a New Beginning, Athens Is Lost' Teutone Off-Topic 8 02-14-2012 02:07 AM
95 w140 s500 lost all power richardandleela W140 S-Class 1 12-31-2006 11:22 AM
