Things to look out for....... - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-15-2019, 10:30 AM Thread Starter
Date registered: Feb 2019
All, howdy. With 4 growing children it's time to get something a bit nicer than the wife's Sharan for karting the kids about in and although large, an r class it's tiny compared to my Viano XL so looks like a good value way to step into a classy people mover.
Although I'm more of a fan of the later facelift model, the early "bug eye" versions seem very cheap for what they are.
Anything specific I should look out for? I'm not afraid of big miles and the wife only does 5k miles per year so buying one that is closing in on 200k is a possibility of there is nothing out of the ordinary to worry about on these?
Do they suffer mid nawties Merc rust issues?
Big_boz is offline
post #2 of 12 (permalink) Old 02-15-2019, 04:36 PM
IWantedaJag's Avatar
Date registered: Jan 2014
Vehicle: 2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Quoted: 2606 Post(s)
Avoid air suspension models or try to knock $600 or more off for a coil spring conversion. You really won't notice any difference on our potholed streets.
Listen for rattling timing chains especially on startup.
New catalysts (over $1000) likely as you get close to 200k miles.
I've done 140k miles in mine in just two years and no complaints otherwise.
IWantedaJag is online now
post #3 of 12 (permalink) Old 02-27-2019, 07:49 PM
Lioninstreet's Avatar
Date registered: Jun 2014
Vehicle: '06 SLK55 P30, '12 R350 P2
Quoted: 4 Post(s)
I had an air shock fail in the rear of my '12 R right after I got it last year.
Arnott had a pretty good deal on them (under $200 ea.) with lifetime warranty (if you buy it from them) so I changed both along with the Airmatic compressor filter. Labor should be about an hour or so per side. Rumor has it the OE Airmatic shock units are good for an average of 60k-80k miles. So if you can get a service history and don't see they've already been done, the car is on borrowed time.
The only other issues I've had is with the parktronic sensors. (I ended up using the Bosch sensors off ebay as everyone said to avoid the cheap Chinese imports...surprise, surprise) and with the little plastic Pano roof control (got that for $55 off ebay too). Quite a rip for a little piece of plastic but the alternative was the entire front ceiling console assembly.
Lioninstreet is offline
post #4 of 12 (permalink) Old 03-02-2019, 05:33 AM
Look out for dodgy bumper repairs especially on the sides where bumper meets fender (wing in English English). Run over one of those concrete sleepers in a car park, back up, drag the bumper off. The sides are only held by push clips that latch into holes in the sides of the bumper and they break really easily. Effin expensive to replace the front bumper.
post #5 of 12 (permalink) Old 03-08-2019, 05:04 PM
ezzo's Avatar
Date registered: May 2017
Vehicle: 2008 E300 4Matic
Quoted: 27 Post(s)
Hi all,
I too am looking for an R-Class. I see a few on sale here in the Vancouver area. There is a variety of engines. I see gas, bluetec, and blueefficiency. I am confident with DIY on gas, but have no experience at all with diesel. Any advice of eiather diesel options are ok? The cars available for sale are 2006, 2007, 2010 and even newer. Prices vary with Kms, and model year, but I see a 2010 with 100K Km and below the CA$10,000. Is this considered reasonable, or it means something is wrong?
Also, for the 6 passenger models, is it easy to upgrade the middle row seats to fit 3 people
Finally, what's the gas-miage on these? My W211 makes 15L/100Km (~16miles per gallon) in the city because it is 4-Matic and I hate this consumption. Is the R-Class of the same rate?
ezzo is offline
post #6 of 12 (permalink) Old 03-09-2019, 07:12 AM
Date registered: Jan 2011
Vehicle: 2015 Audi S4, 1982 Fiat Spyder, 2010 Mercedes R350, 2013 Mercedes E550 Cabriolet
Quoted: 4 Post(s)
I don't know the price difference in Canada for gas vs. diesel, but in the US, diesel is much more and wipes out the advantage of fuel mileage. Also, diesel engines now seem to require more service and repairs than gas. I'd choose gas. The gas engine had most of the earlier problems worked out by the 2009 model year. 2010 and newer are the safest and will have a more modern Command system. I wouldn't worry about 100k km. as mine now has 150k miles and still runs like new. Pay for any used car to have a full check up by an experienced German car mechanic. Either a different dealer or a good independent. Does CARFAX exist in Canada?
I don't drive much really heavy city traffic with lots of stop and go, but get almost 20mpg in mixed town and highway driving and 22 to 24 mpg on a long trip with fairly fast and sometimes aggressive driving.
ezzo likes this.
gforaker is online now
post #7 of 12 (permalink) Old 03-09-2019, 11:34 PM
Kevin Worrell's Avatar
Date registered: Aug 2017
Vehicle: 2004 W163 Inspiration, 2007 W251, 2012 W251
Quoted: 10 Post(s)
I have two W251's - a 2007 and a 2012. I've got three kids and didn't want another Suburban. Additionally, my wife and I looked at the GL and determined that wasn't as easy to maneuver, park, and that the GL didn't get the mpg of the R.
The 2007 we've had since 2014 and the 2012 I bought in 2017. I've put 80kmi on the 2007 and 30kmi on the 2012. Here's the issues I've had in that time:
2007 R350 Gas Starting Mi 72k, Current Mi 156k
2015 - Replaced a single rear air shock - looked as if the other had already been replaced - no charge repair by seller
2016 - Intake manifold replacement due to idler door linkage breaking - dealer quoted $4850 for repair, local specialist shop did the job for $750 with the exact same parts.
2017 - Brakes - shoes and rotors all the way around, brake flush, LOF - local specialty shop $675
2019 - Broken oil filter housing leak caused misfire only at cold start, replaced tensioner, associated timing components, plugs and coils, some internal parts, dealer wanted $6100 to repair paid $1550 to local specialty shop
2012 R350 Gas Starting Mi 44k, Current Mi 74k
2017 - Weird vibration in rear wheel - Dealer suggested we replace rear axle and diff, forgot the quote amount, local shop fixed the problem by moving the wheels around and rebalancing the tires, no charge
2018 - LOF - specialty shop - $65
2018 - Powered trunk latch assembly failure - $412 did the repairs myself
2019 - Parking Sensors don't function properly - no fix yet
Here's the deal though, with kids, if you're going to buy one of these cars, be sure and buy the version with the captains chairs in the second row - the three-part bench seat is difficult with two baby seats in the second row because you cannot access the third row as the seats won't move forward to allow access with the child seats buckled in place. The rear seat is accessed by opening the hatch back and having your kid crawl in from that direction. It's not a good solution. So if you want to use the third row, get yourself the version without quasi three way bench.
Additionally, the doors are so huge on this car, don't think you can open them in the garage with another car next to you with any sort of ease. I have uploaded a photo which shows this problem. We typically have to back out a car to easily strap two kids in the second row AND insert a kid into the third row.
To be honest, I'm looking to purchase a Mercedes van I haven't decided which version - my wife prefers the $145k AWD Mercedes Van - which isn't too attractive an idea to me.
I do love the R class however, and for some reason I feel like my 2012 is quite a different feeling car than the 2007. They just feel quite a bit different. The 2012 feels lighter and handles a bit better. The interior doesn't feel as quality as the 2007. The 2007 is actually quieter in regards to road noise, the doors seem heavier than the 2012.
These are simply my personal observations, I have no scientific facts backing my statements.
Name:	W251's rear photo.jpg
ID:	2495106   Click image for larger version
Name:	W251's Garage.jpg
ID:	2495108   Click image for larger version
Name:	W251's Front View.jpg
Kevin Worrell is offline
post #8 of 12 (permalink) Old 03-10-2019, 03:06 PM
ezzo's Avatar
Quoted: 27 Post(s)
Many thanks for the feedback. Diesel car prices don't seem to differ much from gas car prices for the same model year and condition, but I might be wrong. Nevertheless, I will consider Gas over diesel. Does this car have the M272 engine? This is the engine I have in my 2008 W211 E-Class, and I am very familiar with.
The 2010 car I see for sale is gas, with 100K Km (60Kmi) and the asking price is C$10,000 (~US$7000). That's what makes it look suspicious. Yes, Carfax exists in Canada. I will definitely use it.
Thanks again!
ezzo is offline
post #9 of 12 (permalink) Old 03-10-2019, 03:31 PM
ezzo's Avatar
Quoted: 27 Post(s)
First off, I would like to thank you for the detailed reply.
I have 4 kids (youngest is 9 and oldest is almost 14.
What about suspension bushings, control arms, etc.? Any issues with these in either cars?
This is not possible with my kids' ages. My 9 yr old and the 11 yr old will be sitting in the 3rd row if I get the captain chairs in the second row. With the 3-part bench, I am hoping my 11 yr old can sit with her older siblinings in the second row bench, especially since my 11 yr old always suffer from car-motion sickness.
Thanks for the great feedback. I really appreciate it. I have a friend who is an automotive service manager at a "famous" car dealership in Vancouver. He got an R350 as a trade in once and he drove it for a day and hated it. It had the air-matic suspension and he tried all settings and he still could not like the handling. I have yet to test-drive one myself to check. I am not a big fan of air-matic due to the potential service costs, and I would be happy with an R-Class with normal suspension.
He also mentioned that it had terrible gas-milage (~12mpg city). I think this was because it was a trade-in and the previous owner probably hadn't serviced it for a while prior to the trade-in.
ezzo is offline
post #10 of 12 (permalink) Old 03-10-2019, 04:34 PM
Quoted: 4 Post(s)
Originally Posted by ezzo View Post
I have a friend who is an automotive service manager at a "famous" car dealership in Vancouver. He got an R350 as a trade in once and he drove it for a day and hated it. It had the air-matic suspension and he tried all settings and he still could not like the handling. He also mentioned that it had terrible gas-milage (~12mpg city). I think this was because it was a trade-in and the previous owner probably hadn't serviced it for a while prior to the trade-in.
A few owners here on the thread state that after they installed a lowering kit, handling did improve enough to be noticeable (better). But nothing will change the fact they are two and a half tons. Don't forget that all R's have airmatic in the back.
Re: Your buddies input on the R's gas-mileage. From your description Im guessing he was driving a r500 (since it's quite rare for any year of r350 to have four corner airmatic). The 3.5l is a much more efficient engine. I average slightly over 20 mpg on my '12 if I lightfoot it.
But if your looking at a 3.5l and it's older than a '12 (I think the issue was on pre '09) check VIN and make sure the car is either not effected by the balance shaft issue or using a car fax / dealer warranty report make sure it has been warrantied.
ezzo likes this.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
2006 CLS500 Phone Installation (verified things needed?)... ShannonRawls C219 CLS-Class 31 08-09-2017 07:46 PM
Let The Lyrics Speak Shane Off-Topic 204 01-20-2014 08:01 AM
Code popping on my SLK230 and need help finding things before I go nuts Kompressed230xs R170 SLK-Class 2 06-06-2012 12:01 PM
An Open Letter to those who don't understand What the Occupy Movement is about The Proctologist Off-Topic 1431 02-07-2012 08:41 AM
things i need... poorboy W201 190-Class 1 08-20-2002 07:57 PM
