2010 R300 suspension bush refresh - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-07-2018, 04:09 AM Thread Starter
Date registered: Apr 2014
Vehicle: 2010 MY11 R300 CDI
Quoted: 2 Post(s)
Hi All,
We’ve been enjoying our 2010 w251 for nearly 5 years and at over 110,000kms I’ve only changed the front struts/bags and am about to do the rears suspension wise.
Aside from that I have just been doing basic maintenance of filters/oils etc.
The front is starting to rattle a fair bit though when going over small bumps etc and I’m thinking it’s time to replace the suspension bushes.
I’m not sure where to start though. Does anyone know of a kit you can buy or which parts are most likely to have worn and should be replaced?
Ours is a 4matic with Air suspension
onnzo is offline
post #2 of 8 (permalink) Old 10-14-2018, 02:43 PM
Date registered: Oct 2018
Not sure if they service Australia, but these are the guys I use. Very knowledgeable, and EVERYTHING comes with a LIFETIME warranty. yes, everything...even brake pads and rotors! Check em out.
http://www.fcpeuro.com/
08_CDI is offline
post #3 of 8 (permalink) Old 10-14-2018, 04:45 PM Thread Starter
Quoted: 2 Post(s)
Thanks - it looks like they international shipping options as well.
Is anyone aware of common issues with bushes/parts that I should check first?
onnzo is offline
post #4 of 8 (permalink) Old 10-16-2018, 07:43 AM
I can't link because I'm at work, but check out the "Legit Street Cars" channel on Youtube. The Vlogger was a Mercedes Journeyman(as was I) and just put out a great video on front control arm bushings, including several replacement techniques and even performance bushings. Excellent channel, very informative. He has an E55 Kompressor that is fantastically modified, a C55 and a C43 that he features. This should be all the info you need.
-Scott
08_CDI is offline
post #5 of 8 (permalink) Old 10-16-2018, 10:15 AM
Granted, the R has different suspension arms, but the bushings/bearings are pressed in just the same...
08_CDI is offline
post #6 of 8 (permalink) Old 10-19-2018, 10:41 PM Thread Starter
Quoted: 2 Post(s)
Thanks for the YouTube clip. I’ll start with the control arm bushes. I’ll have a look when the rear bags arrive.
onnzo is offline
post #7 of 8 (permalink) Old 02-06-2019, 03:02 AM
SimonOHC's Avatar
Date registered: Nov 2009
Vehicle: 2008 CLK63AMG Black Series & 2011 R350CDI
Hi Onnzo,
good to know that you are from Australia, so am I and I am in the midst of doing the same front suspension work and wonder if you could share your experience and your recommended shop for the work. I am in Sydney.
My R has a soft thud sound whenever I hit a hump or a dip.... not the metal to metal kind of sound but more like spring/rubber rebound.
Tqvm for your feedback.
SimonOHC is offline
post #8 of 8 (permalink) Old 03-22-2019, 11:42 AM Thread Starter
Quoted: 2 Post(s)
I only got a chance to look at this recently and went through all the main bushes looking for wear.
All looked good except I found a torn cv boot...
Further investigation indicates the sound I’m hearing is the steering rack bushing. Will check it out after I’m back from holidays.
https://www.benzworld.org/forums/w25...2022465?page=2
onnzo is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
