Nasty rattle coming from engine bay on starting - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-20-2018, 12:03 PM Thread Starter
IWantedaJag's Avatar
Date registered: Jan 2014
Vehicle: 2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Quoted: 2537 Post(s)
2012 R350 4Matic. Same engine and tranny as the ML350 I am told so I am posting here and in the ML section.
I'm getting a nasty rattle coming from the engine compartment when I start the engine. It's either something loose inside the engine bay or something much much worse.
Rattles, then settles down to nothing one the engine is running. Seems to be coming from the left side (driver's side/ port side) of the engine bay.
Any ideas anyone? I'm going to try and get the Memsahib off her derriere and start the engine while I look and listen, but failing that or some good advice here, I guess I'm going to have to wait for something to happen....
"Semper In excretio, solum profundum variat" - unknown
They called me mad, and I called them mad, and damn them, they outvoted me" - Nathaniel Lee
IWantedaJag is online now
post #2 of 12 (permalink) Old 03-26-2018, 08:17 PM
Date registered: Jul 2013
Quoted: 6 Post(s)
I too get some kind of crazy sound upon starting the car but it goes away almost immediately once the engine gets going. And it only happens when thecv at has been sitting few a couple of days. No way to know if our problems are th e same without hearing the sounds though.
Sent from my SM-G950U using Tapatalk
ODIOUS* is offline
post #3 of 12 (permalink) Old 03-28-2018, 11:54 AM Thread Starter
Asked on the ML page (the R has the same engine and tranny as the ML) and the collective wisdom seems to be the timing chain tensioner sticking when cold. Apparently there was a recall to fit a check valve in the pressurized oil line that operates the tensioner on the MLs, so I presume it also applies to the Rs. Going to check if that's the case and if so whether mine ever had the recall acted upon.
post #4 of 12 (permalink) Old 03-28-2018, 01:20 PM
Quoted: 6 Post(s)
Pls keep us posted if you hear anything regarding this. Wonder if this is just an annoyance or if it has the potential to cause engine problems down the line?
ODIOUS* is offline
post #5 of 12 (permalink) Old 05-06-2018, 05:05 AM
Date registered: May 2018
Vehicle: R350 4Matic
Whoah mines started too' ..but get this ..it Started as soon as i Replaced the Power Steering Pump...when i replaced the Pump i didnt get to switch the resevoir..so im thinkin that might be it....i think..
BenzBallin is offline
post #6 of 12 (permalink) Old 05-12-2018, 06:30 AM
Lioninstreet's Avatar
Date registered: Jun 2014
Vehicle: '06 SLK55 P30, '12 R350 P2
Quoted: 4 Post(s)
I've had two '12 R's and they both do it. Doesn't sound like a lifter clatter but something loose inside the motor. Very weird sound. Tech told me they all do that... Not very comforting.
Lioninstreet is offline
post #7 of 12 (permalink) Old 05-14-2018, 03:41 PM
Date registered: Jan 2011
Vehicle: 2015 Audi S4, 1982 Fiat Spyder, 2010 Mercedes R350, 2013 Mercedes E550 Cabriolet
Quoted: 4 Post(s)
Well, I can't say they all do it. My 2010 doesn't with 135k miles.
gforaker is offline
post #8 of 12 (permalink) Old 05-14-2018, 03:51 PM
Quoted: 4 Post(s)
From what I found talking to techs, there is a startup rattle that's unique to the m276 gas motor. That motor is only on the 2012 R
post #9 of 12 (permalink) Old 05-14-2018, 04:01 PM Thread Starter
Mine started doing it at about 140k miles.
Oil change due soon so I'm going to try an engine flush to see if that unclogs anything...
post #10 of 12 (permalink) Old 07-10-2018, 12:55 PM
Quoted: 6 Post(s)
What is your engine flush procedure?
ODIOUS* is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
