Won't Start in Hot Weather/Direct Sun - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-21-2016, 11:22 AM Thread Starter
Date registered: Sep 2016
Vehicle: 2010 R 350
I've read a bunch of posts on this subject, but there didn't seem to be a clear solution. Here is my situation:
1. Whenever the sun is directly on the car and the interior temp jumps, the car won't start. It doesn't turn over. The dash digital instrument lights come on, but they can go dark too. I can get the instrument lights to come back on by opening and closing the doors.
2. If we open all the doors and get cooler air flow inside the car, it will eventually start. We noticed that when the temp reading on the dash is around 83 or below, our chances improve. The air flow trick can take up to 30 minutes to work.
3. The car starts right up every morning because the cabin temp is low.
4. If I park the car in the shade and keep the windows open I am usually okay.
When it doesn't start, the engine doesn't turn over at all. It behaves just like a dead battery.
If anyone has figured this out and can help, I would be very grateful.
bumps44 is offline
post #2 of 6 (permalink) Old 09-21-2016, 02:20 PM
Kajtek1's Avatar
Quoted: 1935 Post(s)
Doesn't R have battery under passenger seat?
When cabin gets hot, the battery gets hot and batteries don't like excessive heat.
Then 83C is quite different from 83F, so would be nice if you could precise?
I would start with checking all electrical connections and next time check the voltage starting on battery prongs and ending on main fuse box terminal.
Welcome to the forum.
Kajtek1 is online now
post #3 of 6 (permalink) Old 09-24-2016, 09:18 AM Thread Starter
Vehicle: 2010 R 350
I have an update, but still having problem:
1. The temp is 83F when the odds for starting improve. The battery is located under the drivers seat, so yes it is subjected to the high temps inside the car when the sun is beating down.
2. I read a number of posts that recommended changing the battery. Mine was the original that came with the car, so it was time for a change. I successfully did the swap this morning and it started right up. I let the car sit in the sun for an hour and unfortunately the car is behaving exactly as I described in my original post.
Any other suggestions?
Thanks!
bumps44 is offline
post #4 of 6 (permalink) Old 09-25-2016, 01:36 PM
YuChem's Avatar
Date registered: Jul 2010
Vehicle: 2012 R350 BT
Quoted: 4 Post(s)
Send a message via MSN to YuChem
1. The battery is under the passenger seat, not driver seat.
2. There is a service menu to check main battery voltage. Try it in different conditions.
1. Make the dashboard show the current speed (0 mph)
2. Press the odometer-reset button three times.
At this point the menu should show the battery voltage.
Try playing around with turning on lights or the ventilation and see how it affects the voltage.
To toggle the menu off, turn the key all the way back.
YuChem is offline
post #5 of 6 (permalink) Old 04-26-2019, 09:14 AM
Date registered: Apr 2019
Exclamation wont-start-hot-weather
A have te same problem with my W212, E class 2010. It won't start on sunny and hot days. I have to wait to fressh the air and low the temperature for some minutes to recognise the key and to start.
Please who has any idea or bumps 44 if reads to help me!
E Class 2010, w212 is offline
post #6 of 6 (permalink) Old 05-06-2019, 07:28 AM
IWantedaJag's Avatar
Date registered: Jan 2014
Vehicle: 2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Quoted: 2459 Post(s)
Suggestions:
1. Leave the sunroof, very rear windows and or the main windows cracked open a little. That allows a little air to circulate and keep cabin temperatures down but thieves are unlikely to get in.
2. Buy a dash sunshade.
3. Move to Scotland.
4. Get the battery checked out, it could be on its last legs.
Oh Kajtec, you do realize 83 Celsius is 181 Fahrenheit, right? Highly unlikely even in the middle of the Sahara!
"Semper In excretio, solum profundum variat" - unknown
They called me mad, and I called them mad, and damn them, they outvoted me" - Nathaniel Lee
IWantedaJag is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
