Please Help! 2009 R320 Bluetec limp mode w/codes - Page 2 - Mercedes-Benz Forum
post #11 of 30 (permalink) Old 01-05-2016, 06:54 AM
Date registered: Aug 2013
Vehicle: R class
Thanks for the quick response Danosll,
The engine sounds like when there is a big exhurst leack, but its all from the engine area not outside or back of car.
Today I intend to clear all the codes with a scan tool , let the engine run , cheak for leaks around hoses as you said , and see what code comes back.
Please, Other opinions and suggestion are welcome
Benzzaa is offline
post #12 of 30 (permalink) Old 01-05-2016, 07:25 AM
Date registered: Jun 2012
Vehicle: 03 sl55 amg, slk230 hers, 06 e350 4matic estate black 7 pass, 97 sl500 red 2013 ml350 bluetec
Check the rubber air hoses from intercooler about a 2" diameter. One on top one on bottom. You should be able to pinpoint leak while engine is running follow the sound. Check lower first
danosll is offline
post #13 of 30 (permalink) Old 01-05-2016, 08:34 AM
Vehicle: R class
I'll pay extra attention but there is no hissing noise to follow
Benzzaa is offline
post #14 of 30 (permalink) Old 01-05-2016, 04:02 PM
Vehicle: R class
Update-
Cleared all codes and got it out of limp-
Start car and idle for a few minutes ,
Drove only about 200meters and car went back in limp.
Two codes came back
P0404
P0471
Plus I was able to isolate the leak sound to the front left side (pasenger) by the big hose to at the intercooler. I can hear it a bit to the right side too but more to the passenger side.
Benzzaa is offline
post #15 of 30 (permalink) Old 01-05-2016, 04:27 PM
You will probably find that the hose has burst. It might be oily around the hole. Try sqeezing it or just remove it entirely to inspect it. Not sure of your year but later models 2010+ are just clips that pop off with a screw driver. Earlier has a gear clamp on one end
danosll is offline
post #16 of 30 (permalink) Old 01-05-2016, 04:37 PM
Or build a pressue tester . take a 1/4 " thick piece of plexi or aluminium. Using the appropriate size holesaw cut out a piece the same size as your intake at turbo (where air box attaches to turbo ) . tap pilot hole made by holesaw to accept Schrader valve. Using an apropriate size hose and 2 gear clamps clamp your tester in front of turbo supply approx @15psi of air with a tire chuck . if hole isn't instantly visible .spray soapy solution all around till you find leak. Almost identical to tool MB dealers use
danosll is offline
post #17 of 30 (permalink) Old 01-09-2016, 08:18 AM
Vehicle: R class
Update-
No boost from turbocharger, back to MB for a replacement.
Benzzaa is offline
post #18 of 30 (permalink) Old 01-09-2016, 09:06 AM
Originally Posted by Benzzaa View Post
Update-
Two codes came back
P0404
P0471
unlikely its the turbo itself . computer wont allow it to produce boost(via the waste gate) if it detects other problem and goes into limp mode.
simple way to verify turbo is to remove airbox and duct at turbo (just a gear clamp) you will clearly see impeller. turn it with your finger, should turn freely and be free from oil and no bent or boken blades .
have you eliminated an air leak as probable cause?
those 2 new codes are egr related so check for exhaust leak. maybe dirty egr. but unlikely the turbo itself
danosll is offline
post #19 of 30 (permalink) Old 01-09-2016, 09:35 AM
Vehicle: R class
I correct myself the car never went in limp at anytime.
Not enough power coming from the engine to shift tranny.
I remember about a yr ago on a trip, the car lost power and speed dropped and i turned of the engine , restart and everything was fine till now.
My question is could it be the faulty exhaust back pressure sensor that overworked the turbo overtime?
And how come such delicate part of the engine dose not throw CEL
Probably a good idea to scan car regularly for codes
Benzzaa is offline
post #20 of 30 (permalink) Old 01-09-2016, 11:15 AM
highly unlikely it is turbo
you can perform a quick test of 118900 ex press sensor see photo.
and charge sensor 123900 see photo
ID:	1734218   Click image for larger version
ID:	1734226   Click image for larger version
ID:	1734234   Click image for larger version
danosll is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
