Leaking oil cooler or oil coolers seals in '07 R320 - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 06-19-2013, 11:53 AM Thread Starter
Date registered: May 2009
I was told that there was an oil leak in the back of the engine, not the kind that leaks on the ground. The mechanic investigated more and said it is likely either an oil cooler or oil cooler seal leak, and that it would be around $1000-$1300 to fix. He rated this leak a 6 on a scale of 1 to 10 in terms of urgency, and said it will only get worse.
Has anyone had experience with this before? Thanks.
Edit: I should add that my concerns are the cost and the "hidden" aspect of this leak. I'm used to oil leaks showing themselves as drips on the ground.
kumarp is offline
post #2 of 19 (permalink) Old 06-20-2013, 07:08 PM
Date registered: Aug 2009
There have been previous reports of oil cooler seal leaks on the forums. How much oil is being lost? How much do you need to add over what range of miles?
If the leak is not apparent, and you don't need to add much oil, probably not a lot to worry about at this point. it might just be a bit of seepage noticed by the mechanic.
PeteinLongBeach is offline
post #3 of 19 (permalink) Old 06-22-2013, 04:16 AM
Date registered: Jul 2007
Vehicle: 2002 MB C230K, 1985 MB 300T Turbodiesel
Quoted: 9 Post(s)
"It doesn't leak on the ground" is code for "weepage".... . Basically the leak is so slow that it weeps down the engine and then as you go down the road, the droplets are blown away. As it gets worse, it still may not hit the ground but rather start to coat the underbody. I have driven old Alfa Romeos that weeped and would coat the entire undercarriage in a thin film of oil (we called it rustproofing...). We never repaired these small leaks as you could drive yourself crazy (and empty your bank acct) trying to track them down and fix them. Never had a problem letting them go and would only fix if I started to see puddles on the driveway. I also have a newer BMW and Mercedes C230 with weepage (but no puddles) and have let them go for years with no issues.
The key is to monitor your dipstick monthly to make sure don't drop too low. My "weeping" C230 goes 3000 miles between top-offs (i.e., these are SLOW leaks).
Once you start losing significant amounts of oil at the oil cooler, it will show up on the ground; do the repairs then (and get a second opinion).
ptbowman is offline
post #4 of 19 (permalink) Old 06-22-2013, 09:32 PM Thread Starter
Thank you for these replies. They are very helpful.
kumarp is offline
post #5 of 19 (permalink) Old 07-02-2013, 10:33 AM
Date registered: Dec 2011
Vehicle: 2008 R320 CDI, 2006 smart fortwo cabrio, 1983 240D, 1982 300SD, 1980 300SD, 1978 280SE EURO
Quoted: 8 Post(s)
First, I highly doubt any shop can fix oil cooler leaks for under a thousand, there is reportly 12 hours of labour involved by an experienced mechanic, lots more for a first attempt! It is a difficult job...
Second, replace the turbo intake seal and crankcase breather hose seals first, they are always leaking on the OM642 engine and lots of compliants on the forums about it, no real fix using Mercedes parts, just constant seal replacement. There are other things that can be done if you search around like a catch tank etc.
Third, replace those two seals mentioned above and then thoroughly clean out the intake valley with degreaser etc and wash, flood the entire valley area with cleaners to rid the oil build up. Then decide if you need an oil cooler resealing or not. It is very hard to determine the source sometimes.
moosejaw5.0 likes this.
houseofdiesel is offline
post #6 of 19 (permalink) Old 07-20-2013, 12:39 PM
chucelli's Avatar
Date registered: Aug 2006
Vehicle: 2000 E430 4Matic, 2007 R320 CDI, 2012 E63 P30, 2013 SLK250
Quoted: 13 Post(s)
houseofdiesel hit the nail on the head.
The turbo intake seal is the most common cause of oil leaks so far on this motor. It seems that this seal needs to be replaced every time the fuel filter is replaced because it gets disconnected in the process and is very prone to failure and/or installation problems. You can see the seal (part # A6420940080)here.
-Robert
chucelli is offline
post #7 of 19 (permalink) Old 10-21-2013, 08:06 AM
Date registered: Nov 2010
Do not buy any Mercedes Benz with an OM642 diesel engine. You will be spending at least $2400 for oil cooler related repairs every 80K miles. The engine design is flawed. MB knows about it but suppresses the statistics on how frequently they are getting these engines in for repair at 80K miles.
Need a good lawyer for a class action lawsuit for this lemon engine. For shame!
Since the 1979 300SD with the rubber oil cooler hoses that burst and dump your oil out to the new OM642 diesel engine they want to put in MLs, E320s, E350s, Sprinters, Chrysler 300s, Cherokees, Mercedes Benz engineers still haven't figured out how to do oil cooling right.
MarcPearl is offline
post #8 of 19 (permalink) Old 05-28-2014, 06:47 PM
Date registered: Dec 2007
Vehicle: 2007 R320 CDI
I just had this looked at and repaired. The MB dealer said that because I was changing the oil every 6500 miles with an extractor that I never would have picked up the oil cooler failure. The car has 142100 miles the cost for that repair was $2400 I also had a front passenger seatbelt sensor go ? That is why I originally brought the car in $500. for the seatbelt with new sensor.... It caused the SRS to fault. All total with some other recommended trans and brake bleed $3,599... that was after my 100,000 mile customer discount. I hope my oil changes every 6 to 7k pays off with another 140,000 miles of care free miles. The tech said that there was 50 lbs of oil that had soaked into the bottom engine cover???
drfred is offline
post #9 of 19 (permalink) Old 05-28-2014, 07:21 PM
Date registered: Sep 2013
Vehicle: 2006 R500
Quoted: 2 Post(s)
50 lbs of oil is like 6 or 7 gallons of oil. What kind of cover is he talking about??? The underbody cover that shields from road debris or some other engine componenet??? And does the R500 have one of these covers???
starbound01 is offline
post #10 of 19 (permalink) Old 05-29-2014, 05:37 AM
I know? I was not there the wife picked up the car. She said that he made it sound like a sponge...I would just keep sopping it up?
drfred is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
