R251 DIY - Page 2 - Mercedes-Benz Forum
post #11 of 23 (permalink) Old 01-29-2010, 03:10 PM
Date registered: Jun 2009
Quoted: 2 Post(s)
R350 DIY Aftermarket HID Installation
https://www.benzworld.org/forums/w251...-tutorial.html
tabocat is offline
post #12 of 23 (permalink) Old 04-28-2010, 08:10 AM
Quoted: 2 Post(s)
DIY Dust Filter Replacement
See link below...
https://www.benzworld.org/forums/w251...procedure.html
tabocat is offline
post #13 of 23 (permalink) Old 05-07-2010, 07:38 PM
Quoted: 2 Post(s)
tabocat is offline
post #14 of 23 (permalink) Old 01-18-2011, 02:24 AM
Outstanding Contributor Always Remembered RIP
eric242340's Avatar
Quoted: 334 Post(s)
Fuel filter DIY, thanks to Lippens:
ERIC.
This definition tells you all you need to know about 'PC'
PC, aka, Political Correctness, is a doctrine, fostered by a delusional, illogical minority (Liberals/Socialists) and promoted by the mainstream media, which holds forth the proposition that it is possible to pick up faeces by the clean end.
eric242340 is offline
post #15 of 23 (permalink) Old 01-24-2011, 12:20 AM
eric242340's Avatar
Quoted: 334 Post(s)
Service reset procedure
R Class service reset procedure:
ID:	353315   Click image for larger version
ID:	353316   Click image for larger version
ID:	353317   Click image for larger version
ID:	353318   Click image for larger version
ERIC.
post #16 of 23 (permalink) Old 02-27-2011, 06:21 PM
eric242340's Avatar
Quoted: 334 Post(s)
Service reset procedure PDF
http://www.startekinfo.com/StarTek/o...tedDocId=10502
ERIC.
post #17 of 23 (permalink) Old 08-30-2011, 05:37 AM
eric242340's Avatar
Quoted: 334 Post(s)
HID Lights
R350 2011.
https://www.benzworld.org/forums/w251...-retrofit.html
ERIC.
post #18 of 23 (permalink) Old 09-07-2011, 08:47 PM
eric242340's Avatar
Quoted: 334 Post(s)
Removing front door lining
https://www.benzworld.org/forums/w251...or-lining.html
ERIC.
post #19 of 23 (permalink) Old 02-12-2013, 07:47 AM
Date registered: Nov 2011
Does anyone have a DIY (preferablly with pics) to do the transfer case fluid change and differentials? I am planning on doing this next week and would like to know all the necessary tools and location of the drain and fill plugs on my 2006 R350. I did a search on google but didn't really come up with anything other than fluid recommendations.
phozenstone is offline
post #20 of 23 (permalink) Old 09-13-2013, 08:06 AM
Date registered: Feb 2008
replace HID lights
Does anyone have any experience replacing the HIDS? Im trying but cannot put the bulb in. Do you know if I need to remove the headlight assembly to do this. awefully complicated!
rmazhuvan is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
DIY/TIPS - Suggestions for the DIY sticky threads Matt L W210 E-Class 151 07-07-2016 06:52 AM
R251 Suspension problem eric242340 W251 R-Class 29 05-14-2011 06:02 PM
Advice on DIY vs. Non DIY Repair Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 10 08-30-2008 10:58 PM
replace rear subframe mounts - DIY or not DIY? philthompson W126 S,SE,SEC,SEL,SD,SDL Class 1 02-02-2007 06:40 AM
DIY stroessel W163 M-Class 7 06-10-2004 01:23 PM
