For those that have the rough 2-1 downshift in "S" mode - Page 2 - Mercedes-Benz Forum
post #11 of 68 (permalink) Old 01-21-2008, 06:38 PM Thread Starter
Vehicle: Eurocharged ECU E500, OE Tuning ECU/Speedriven TCU SL600 V12TT, 2007 Range Rover Supercharged
Send a message via AIM to Benz-O-Rama
Originally Posted by Streetglower View Post
MBUSA has allowed for valve body replacement for years. as long as its approved by WSG, there is a form that team leaders or shop foremans fill out on netstar that requests a valve body or trans replcement on a vehicle. you give MBUSA the vehicle info, issues and what has been done. you get a yes or no answer. now most of the time, techs will just flash the trans control unit. usually a valve body get requested after several complaints or when a fault is stored in the tranny. 99% of faults that occur in the tranny require a new valve body.
I hear ya...
I guess that's why they had to state the WSG case on my worksheet. What the hell is a WSG anyway?
Thanks for the info.
2004 E500 - Eurocharged ECU, VRP headers and E55 exhaust. #1 record holder on dragtimes ([email protected])
2005 SL600 - OE Tuning ECU/ Speedriven TCU - #1 record holder on dragtimes ([email protected])
Powered by:
Benz-O-Rama is offline
post #12 of 68 (permalink) Old 01-22-2008, 01:41 AM
Date registered: Jan 2007
Vehicle: 2002 honda civic (sold), 2009 Mercedes ML350
Quoted: 4 Post(s)
WSG is warranty services group
Streetglower is offline
post #13 of 68 (permalink) Old 01-22-2008, 12:56 PM
Vehicle: 07 R320 CDI
Difference between "jerky upshift" vs "rough downshift"?
Originally Posted by chucelli View Post
anyone else have the same success story?
I've been having the rough downshift to 1 since day 1 and it would be great if this is the cure...
RDriver, have you taken your R in yet?
Chucelli - Not yet but I will when I bring my car in for the Service A at 10,000 mile (in a month to two). I'll post afterward.
Chucelli / or Anyone - What have you experienced with the "rough downshift to 1"? Does it happen all the time? When it does, is it "mild", "medium", or "hard"? Mine is very "mild" and happens 25% of the time (coming to the stops), which makes me feel that it is "normal" until I read/saw BenzOrama post.
For jerky up shifts of 2-3 or 3-4, going uphill at slow speeds, I have had 3 software updates (at 800 miles, 2000 miles, and 6,800 miles). Those are gone, and up shifting is very smooth except for very occasional jerks (once in evey 2 to 3,000 miles).
But this jerky "upshift" from 2-3 I assume is different than the rough "downshift" from 2-1, coming to a stop. And, I plan to take it up to the SM for a "valve body" replacement, based on BenzOrama advice.
Anyone with either upshift/downshift experience, please share.
RDriver is offline
post #14 of 68 (permalink) Old 01-22-2008, 05:41 PM
chucelli's Avatar
Date registered: Aug 2006
Vehicle: 2000 E430 4Matic, 2007 R320 CDI, 2012 E63 P30, 2013 SLK250
Quoted: 13 Post(s)
RDriver,
I feel my 2-1 downshift every time when stopping but I would say it's "mild", meaning right before reaching a complete stop, it will feel like all the sudden the car breaks harder for the last 10 MPH or so. If I brake VERY gently, to the point of almost riding the brakes, I can minimize that feeling of the 2-1 shift.
Other shifting anomalies I've noticed are very harsh shifting at certain times when I let off the throttle gently after a hard takeoff (or going up hill). I haven't yet been able to reliably reproduce that behavior however...
It may be the jerky upshifts you seem to be experiencing.
hope this helps.
chucelli is offline
post #15 of 68 (permalink) Old 01-23-2008, 02:07 AM
Quoted: 4 Post(s)
also a rough 2-1 downshift doesnt necessarily mean you need a valve body or software update. adaptations have to be checked first because if your b1 and b3 clips have come apart in the transmission, it will cause a hard jerk right before you come to a stop. E classes and ML and R classes have been the most common cars that i have replaced clips in.
post #16 of 68 (permalink) Old 01-23-2008, 06:18 AM
gst500's Avatar
Date registered: Sep 2007
Does anyone get the rough shift from 1st - 2nd? I occasionally get the downshift from 2-1 but not enough to bother me. But what I do get is rough shifting from 1-2, its like 1st gear shifts too early. The rpm's only go to about 2000 rmps and than shifts to 2nd. This also affects acceleration because 1st is not getting drawn out long enough and I am loosing the powerband. Has anyone experienced this, if so does the updated sofware help?
gst500 is offline
post #17 of 68 (permalink) Old 01-25-2008, 07:37 PM
mitaka's Avatar
Quoted: 4 Post(s)
Oh Yes
Rough 1st 2nd is very common. Especially after software updates. It dove me crazy. I had a few trips to the dealer for that. I had to bring it to another dealer where the tranny specialist had to update both the ECU and Tranny software. I still feel it a bit but it is almost gone. The more you drive it the better it gets.
2012 E550 P1, Driver Assist Pkg, Sport Pkg 18' OEM AMG Wheels, Distronic
Other/ Previous cars:
14 Volvo XC60 T6 AWD
09 R350
07 R320 CDI
Audi A8 4.2 Quattro
mitaka is offline
post #18 of 68 (permalink) Old 01-25-2008, 07:41 PM
mitaka's Avatar
Quoted: 4 Post(s)
I spent a lot of time researching this issue. There is a software update that fixes these issues but it works only on the newer valve body. In other words if you have the old valve body you cannot use this current software version.
09 R350
07 R320 CDI
Audi A8 4.2 Quattro
mitaka is offline
post #19 of 68 (permalink) Old 01-27-2008, 01:58 AM
How do you know if you have a new one?
All '06s and '07's have the old valve, by default, unless been replaced?
Mind sharing more info on your researching.
Thanks.
RDriver is offline
post #20 of 68 (permalink) Old 01-27-2008, 03:37 PM
mitaka's Avatar
Quoted: 4 Post(s)
I was told that if you have the bad older valve body you the car won't take the newest software version.
09 R350
07 R320 CDI
Audi A8 4.2 Quattro
mitaka is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W251 R-Class
Thud from "Comfort to Sport" Mode & Memory Power Seats CHLUTES W203 C-Class 7 10-21-2007 03:22 PM
"Manual" mode on 7 speed auto SLK350 PhilD73 R170 SLK-Class 1 04-24-2006 06:15 AM
Your SLK "Primary" or "Secondary" mode of transportation? 2000 SLK 230 LM R170 SLK-Class 23 05-05-2004 09:35 AM
one touch sunroof & "tunnel mode"? dan2003 W203 C-Class 8 05-18-2003 09:23 PM
