Heater problem - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-13-2018, 10:56 AM Thread Starter
Date registered: Nov 2018
Vehicle: B250 (W246) 2015, 2L, Base, automatic.
Heater problem
Has anyone ever had a heating problem? I live in a cold area (-10C to-20C) and the thermostat rises only very VERY slowly. The engine reaches its optimum temperature (90C) after 15-20 kilometers. An explanation or a solution?
B250 2015 (W246) with 2L motor, base, automatic.
(Bing translation)
Wadabadou is offline
post #2 of 5 (permalink) Old 12-14-2018, 06:16 AM
Hey Hoser's Avatar
Date registered: Mar 2013
Vehicle: B250 2013 Red, Honda 2018 CR-V Touring, Dark Blue
Quoted: 7 Post(s)
Hi, no problems with my 2013, heats up cabin fairly quickly, and seat warmer helps
possibly your thermostat in engine?
Hey Hoser is offline
post #3 of 5 (permalink) Old 12-17-2018, 10:14 AM
Date registered: Nov 2014
Vehicle: B250
Quoted: 20 Post(s)
(Bing translation)
I think this is about normal. The engine really does take a long time to heat up compared to my other car (Hyundai Santa Fe 2.4). I think it's because it's a smallish engine with turbo, so it doesn't need to rev much to reach intended speed. Have you tried revving higher in the first few minutes (e.g. put it in sport mode)?
rk21 is offline
post #4 of 5 (permalink) Old 12-17-2018, 10:16 AM
Vehicle: B250
Quoted: 20 Post(s)
And I just noticed you also have the base model like mine. We don't have automatic climate so the car doesn't get to decide the optimal fan speed to heat up the car. I wonder if the others with auto climate don't have the same problem.
rk21 is offline
post #5 of 5 (permalink) Old 12-18-2018, 07:41 AM
Date registered: Feb 2013
Vehicle: 2013 B250
Quoted: 23 Post(s)
I notice the same thing in my B250. I recall reading somewhere that if you turn climate control off at first, it gives the engine coolant a better chance at getting warmer in less time. I gave that a try and it does work, but it only shaves a couple minutes off the time it takes to warm up. What others have said about the low revs is true. I find that normal city driving takes forever to warm up the engine because of the low revs in Eco mode. But as soon as I get on the highway, it finally gets to do the kind of work needed to warm things up quicker. One trick I have tried is to switch to manual mode and keep the revs a bit higher using lower gears until warm-up. But then you'll use more gas.
kplesz is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W246 B-Class
