Engine chokes at street lights - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 06-27-2019, 12:51 AM Thread Starter
Date registered: Dec 2016
Vehicle: B200 / 2006
Quoted: 4 Post(s)
Question Engine chokes at street lights
It started a couple of days ago. The car engine starts and runs without issues.
The problem is: At low speed 25-30 km/h the engine chokes and the car feels rough and bouncy. It happens when stop and start at street lights. Once over 40 km/h it runs fine... but the car is not reliable now...
Any suggestions?
Thanks,
mark0n is offline
post #2 of 22 (permalink) Old 06-27-2019, 01:38 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 154 Post(s)
Blocked cat may be .
This is a retro ride .
plinker17722 is offline
post #3 of 22 (permalink) Old 06-27-2019, 04:28 AM
pfsantos's Avatar
Date registered: Nov 2005
Vehicle: '83 W123 200 '98 E200 Kompressor (both Euro-spec., 200 in Portugal, E200 Now in Canada!), '08 B200
Quoted: 136 Post(s)
Any codes? Manual or automatic transmission? If auto, does it downshift when slowing down to a stop? How does it idle when fully warmed up while parked?
Paul (Paulo Santos)
Youtube:
'83 W123 200, '98 W210 E200K, '08 W245 B200
* Feel free to PM me if needed *
pfsantos is offline
post #4 of 22 (permalink) Old 06-27-2019, 09:11 AM Thread Starter
Quoted: 4 Post(s)
Unhappy
No codes displayed. Nothing.
Automatic transmission.
Yes it does downshift. No issue. (it might be just my imagination "when slowing down to a stop" is not exactly as smooth as it used to be. Maybe it's only me that can feel it... Maybe just imagination)
Idle is fine. No issues.
Thanks,
mark0n is offline
post #5 of 22 (permalink) Old 06-27-2019, 09:17 AM Thread Starter
Quoted: 4 Post(s)
Not sure what a "Blocked cat" means...
mark0n is offline
post #6 of 22 (permalink) Old 06-27-2019, 09:28 AM
Date registered: Aug 2009
Vehicle: 2006 B200T
Quoted: 87 Post(s)
Thanks,
More than a few owners on this forum have this issue. I have had it for a while now. My mechanic thinks it is the spark plug wires. They are tiny misfires and barely felt but at low speeds, usually idling at a light, you can feel them. The needle bounces ever so slightly. I'm getting my plug wires changed mid July. Will report on if it fixes the issue. They are expensive because of the 90 degree bend at the end, and they are heat shielded wires. They cost more than a set for a V8 S class and getting to these plugs are a real b*tch. Oh, I have a turbo BTW.
vanctour is offline
post #7 of 22 (permalink) Old 06-27-2019, 10:12 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 537 Post(s)
It refers to a "blocked up" catalytic converter..meaning that there is a restriction in the exhaust system and the fumes can't get out of the tile pipe easily....ie: if you ram a potato into the tailpipe, you block the exhaust fumes from exiting...and your car will stall...
Your catalytic converter is a filter with fine holes and fine passageways .. if the holes block up (a lot..) and the car will want to stall.
DEVOURS is offline
post #8 of 22 (permalink) Old 06-27-2019, 10:16 AM
DEVOURS's Avatar
Quoted: 537 Post(s)
Originally Posted by vanctour View Post
................ They are expensive because of the 90 degree bend at the end, and they are heat shielded wires. They cost more than a set for a V8 S class and getting to these plugs are a real b*tch. Oh, I have a turbo BTW.............
The non turbo B's (B200's..etc..) have a straight plug wire,..and they remove with a straight pull or push...not bad at all..
DEVOURS is offline
post #9 of 22 (permalink) Old 06-27-2019, 10:39 AM
pfsantos's Avatar
Quoted: 136 Post(s)
Next time when no one's behind and you see a red light up ahead, shift to Neutral, and come to a stop like you always do. Let us know if anything changes, just to rule out stalling due to the transmission slowing down the engine too much or downshifting too late.
Just to exclude it from possible causes.
Paul (Paulo Santos)
Youtube:
pfsantos is offline
post #10 of 22 (permalink) Old 06-30-2019, 09:55 AM Thread Starter
Quoted: 4 Post(s)
Done / tested this several times. No issues. Smooth, normal stop on Neutral.
mark0n is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
