precautions to be taken before welding work - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 06-17-2019, 11:27 AM Thread Starter
pablo_can's Avatar
Date registered: Dec 2017
Vehicle: w245 2006
Quoted: 50 Post(s)
hi. there is a broken part above left shock mount and need to be welded. do I need to unplug batteries, also ecu or something else? I don't think I can unplug everything so what is the safest way to start this job. thank you.
pablo_can is offline
post #2 of 18 (permalink) Old 06-17-2019, 01:19 PM
pfsantos's Avatar
Date registered: Nov 2005
Vehicle: '83 W123 200 '98 E200 Kompressor (both Euro-spec., 200 in Portugal, E200 Now in Canada!), '08 B200
Quoted: 133 Post(s)
Disconnect negative and positive cables at the battery. Disconnect ECU plugs, just to be safe (I'd do it).
DEVOURS and pablo_can like this.
Paul (Paulo Santos)
Youtube:
'83 W123 200, '98 W210 E200K, '08 W245 B200
* Feel free to PM me if needed *
pfsantos is offline
post #3 of 18 (permalink) Old 06-17-2019, 04:17 PM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
^ Agreed. Make sure your ground has a good, clean connection. Also locate your ground as close as reasonably possible to the area being welded, since 100% of the current will be flowing through the metal between the ground and the weld.
pfsantos, DEVOURS and pablo_can like this.
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #4 of 18 (permalink) Old 06-21-2019, 03:53 AM Thread Starter
pablo_can's Avatar
Vehicle: w245 2006
Quoted: 50 Post(s)
Is car radio going to ask for code after unplugging battery cables? I don't have that.
post #5 of 18 (permalink) Old 06-21-2019, 08:43 PM
Mike Ti's Avatar
Date registered: Aug 2016
Vehicle: B200 5sp, Peugeot 404C Injection
Quoted: 41 Post(s)
Send a message via Yahoo to Mike Ti
yes. And what on earth came of the bodyshell that require welding? You have the worst luck with your car.
pablo_can likes this.
Mike Ti is offline
post #6 of 18 (permalink) Old 06-22-2019, 09:40 AM Thread Starter
pablo_can's Avatar
Vehicle: w245 2006
Quoted: 50 Post(s)
yeah absolutely. my mechanic said metal sheet part over the shock mount is loose and that makes the annoying sound while passing over the bumps. he said I'll remove shock and other parts and probably it'll need welding. can I get the code for radio from the dealer?
post #7 of 18 (permalink) Old 06-22-2019, 11:07 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 514 Post(s)
Would you post a few clear, sharp closeup photos of the problem areas...? A rust out on a B is really strange...
DEVOURS is offline
post #8 of 18 (permalink) Old 06-22-2019, 11:11 AM
Breadford's Avatar
Date registered: Dec 2018
Vehicle: 2006 B180
Quoted: 21 Post(s)
Hey. I’ve had the same problem. I know how annoying is that sound when passing over bumps. In my case that was loosened protective cover of shock absorber. On the top of it, there is white plastic ring which makes that sound. Firstly check protective cover.
forrera and Mike Ti like this.
Breadford is offline
post #9 of 18 (permalink) Old 06-22-2019, 11:57 PM Thread Starter
pablo_can's Avatar
Vehicle: w245 2006
Quoted: 50 Post(s)
Originally Posted by Breadford View Post
Hey. Iíve had the same problem. I know how annoying is that sound when passing over bumps. In my case that was loosened protective cover of shock absorber. On the top of it, there is white plastic ring which makes that sound. Firstly check protective cover.
Are you sure? that white plastic cover is a very light part and I'm not sure it could produce a sound that anyone in the car can hear.
post #10 of 18 (permalink) Old 06-23-2019, 12:07 AM Thread Starter
pablo_can's Avatar
Vehicle: w245 2006
Quoted: 50 Post(s)
I don't think it is a rust problem. When I first bought the car I heard very loud noise on left side and after a while turning steering became difficult. Then I took the car to a mechanic he removed the left spring and the spring was bent, spring was not carrying the car completely. He fixed the spring and a few days later I replaced both springs. Now it begins to make sense, probably previous owner had a small accident that affected left wheel. This loose part could be one of the affected parts I guess. She probably got on sidewalk or something similar and they didn't fix it properly.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
Gammelvind , DieterRewitzky , forrera
