Cannot set correct time in info panel - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-05-2019, 10:21 AM Thread Starter
Date registered: May 2019
Hi all,
Maybe someone can help me to solve correct time setting in info panel.
Recently I was forced to take battery off and of course car time also was set to 12.00 when I connected battery back.
Unfortunately I am not able to set time in info panel to correct back again. I dont know what I do wrong or if I do anything wrong but Im bit pissed off that time is impossible to set.
Added pictures what Im doing to set correct time.
Press ''Serv'' button->System->Time->set correct time and back. In info panel time is still not correct. Tried to find something in ''format'' section under ''time'' but there is only time and date formats and nothing else.
Can someone suggest me how to solve this?
Of course there is hard way to unconnect battery again and exactly on 12.00 connect it back again but...yeah...its the hard way for me as this shold not be the only way to set correct time.
ID:	2518212   Click image for larger version
ID:	2518214   Click image for larger version
ID:	2518216   Click image for larger version
ID:	2518218   Click image for larger version
Raitis Gavrilko is offline
post #2 of 4 (permalink) Old 06-05-2019, 12:49 PM
pfsantos's Avatar
Date registered: Nov 2005
Vehicle: '83 W123 200 '98 E200 Kompressor (both Euro-spec., 200 in Portugal, E200 Now in Canada!), '08 B200
Quoted: 133 Post(s)
I'm not familiar with your version.
Do you have the Command system with Navigation?
There was a thread here on the forum that said the time should auto-correct when it gets a GPS signal.
Maybe try setting a route in navigation to wake the system up?
MB•David likes this.
Paul (Paulo Santos)
Youtube:
'83 W123 200, '98 W210 E200K, '08 W245 B200
* Feel free to PM me if needed *
pfsantos is offline
post #3 of 4 (permalink) Old 06-05-2019, 01:00 PM Thread Starter
Yes, I read that topic but seems gps will not help me because have set route and gps was found but time was still wrong. Im thinking now maybe the fault js version of ntg2 software?! How can I check my current version and upgrade or downgrade versions?
post #4 of 4 (permalink) Old 06-05-2019, 01:37 PM
MB•David's Avatar
Date registered: Oct 2013
Vehicle: A200 Sports Coupé C169 2006
Quoted: 207 Post(s)
I'm afraid I do not have an answer to this problem - I had an NTG2 Audio 20 in my car originally, so the time is set via steering wheel controls in instrument cluster.
David
MB•David is online now
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
