B200 Problems, not sure how to proceed - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-20-2019, 12:43 PM Thread Starter
Date registered: May 2019
Vehicle: 2007 B200 Turbo
Unhappy B200 Problems, not sure how to proceed
Hey guys, I've read your forum months before I purchased this car so I want to thank you all, your knowledge has helped me immensely.
I'm 18 years old and I purchased a B200 Turbo used for a super good price, in good condition. Probably a stupid car at this age, however, I fix everything myself and have access to a hoist and diagnostic computer.
I have been having a recurring issue with the Divert Air Switchover valve stuck in the open position. I replaced the valve located slightly behind and under the inlet tube from the air box to turbocharger, but I'm still getting the same code.
I replaced the spark plugs 2 months ago myself, my god what a PITA that was... Yet I'm now experiencing a misfire on cylinder 1 and 4. Does the coils go Coil 1: Cyl 1,2 Coil 2: Cyl 3,4 or does it go Coil 1: Cyl 1,4 Coil 2: Cyl 2,3? If it's the latter, I will swap ignition coil to see if that is the root cause. Otherwise I think perhaps spark plug wires, or carbon buildup on intake valves?
Sorry for wall of text, thanks for your help.
Anthony
Anthony Penney is offline
post #2 of 6 (permalink) Old 05-21-2019, 04:57 AM
pfsantos's Avatar
Date registered: Nov 2005
Vehicle: '83 W123 200 '98 E200 Kompressor (both Euro-spec., 200 in Portugal, E200 Now in Canada!), '08 B200
Quoted: 124 Post(s)
The switchover valve code could be the part itself (mechanical issue) or maybe the control or operation system (electric / vacuum). Check plugs, connections, and the like.
The ignition issue could be just damaged wires from the plugs change. Check for blue sparks around the area in the dark (WATCH OUT FOR MOVING PARTS) while the engine is running.
Don't have a pic of the wire routing handy right now.
Paul (Paulo Santos)
Youtube:
'83 W123 200, '98 W210 E200K, '08 W245 B200
* Feel free to PM me if needed *
pfsantos is offline
post #3 of 6 (permalink) Old 05-21-2019, 12:05 PM
pfsantos's Avatar
Quoted: 124 Post(s)
BTW, a good scanner will show you misfire counts. Could be especially helpful to have someone watching the scanner while you wiggle wires or spray water (spray bottle) on the wires. Once again, BE CAREFUL with moving and hot parts, and the ignition secondary voltage IS VERY HIGH!!! None of those are fun.
I know I took pics of the area. Let me find my USB drive.
Paul (Paulo Santos)
Youtube:
pfsantos is offline
post #4 of 6 (permalink) Old 05-21-2019, 12:18 PM
pfsantos's Avatar
Quoted: 124 Post(s)
pics
ID:	2514618   Click image for larger version
ID:	2514620   Click image for larger version
MB•David likes this.
Paul (Paulo Santos)
Youtube:
pfsantos is offline
post #5 of 6 (permalink) Old 05-21-2019, 12:22 PM
pfsantos's Avatar
Quoted: 124 Post(s)
asdf
Paul (Paulo Santos)
Youtube:
pfsantos is offline
post #6 of 6 (permalink) Old 05-22-2019, 11:45 AM
pfsantos's Avatar
Quoted: 124 Post(s)
Paul (Paulo Santos)
Youtube:
pfsantos is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
R230 MB SL500 Roof problems MM GARAGE R230 SL-Class 1 04-10-2017 02:03 PM
B200 2008 Base - Muffler "strap" problems Eul0gy W245 B-Class 3 08-09-2016 02:22 PM
B200 Turbo fuel consumption problems rodamm W245 B-Class 17 07-05-2016 08:42 AM
The M-Class, once an anchor on the brand's overall score, improved in 2006 from 159 Quicks W164 M-Class 0 06-10-2007 05:46 PM
Ordered a B200 Turbo today! Just wanna share my experience why... jagged W245 B-Class 6 02-28-2006 10:35 AM
