Axial joint replacement - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 04-23-2019, 06:16 AM Thread Starter
Breadford's Avatar
Date registered: Dec 2018
Vehicle: 2006 B180
Quoted: 22 Post(s)
Hello. I need help, how to replace axial joint on right side?? Is there any special tool for that??
Breadford is offline
post #2 of 9 (permalink) Old 04-23-2019, 09:44 AM
pfsantos's Avatar
Date registered: Nov 2005
Vehicle: '83 W123 200 '98 E200 Kompressor (both Euro-spec., 200 in Portugal, E200 Now in Canada!), '08 B200
Quoted: 133 Post(s)
I'm guessing you mean the right side drive axle.
The only 'special' tool I would say is a tie rod or ball joint puller.
https://www.amazon.ca/GearWrench-391...91363739&psc=1
The fork style tool works, but I like this one more. Search YouTube for "tie rod removal" or "ball joint removal"
You'll also need a "breaker bar" and the correct socket (it's 30-something mm big) to remove the nut on the hub, and preferably a torque wrench to tighten it to spec. Should use a new nut, and they sometimes come with the new driveaxle.
Watch this video. I'm not a fan of banging on the driveshaft to release it from the hub. Not good for the bearing. You can use an air hammer which creates better vibrations with less force. So that would mean two more tools (air hammer and compressor).
MB•David likes this.
Paul (Paulo Santos)
Youtube:
'83 W123 200, '98 W210 E200K, '08 W245 B200
* Feel free to PM me if needed *
pfsantos is offline
post #3 of 9 (permalink) Old 04-23-2019, 11:48 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
Axial joint connects steering wheel with tie rod ( track rod end). Thank you for that video.
post #4 of 9 (permalink) Old 04-24-2019, 07:00 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
The other name is inner tie rod
post #5 of 9 (permalink) Old 04-25-2019, 06:26 PM
pfsantos's Avatar
Quoted: 133 Post(s)
As far as I can tell from Googling inner tie rod for our vehicles, it doesn't look like it needs a special tool like on some cars. It has a bolt that goes through it because the cast thing has an ear on it for the bolt. You may need the band flyer kind of like a CV joint band.
Sent from my SM-A520W using Tapatalk
Paul (Paulo Santos)
Youtube:
pfsantos is offline
post #6 of 9 (permalink) Old 04-25-2019, 06:27 PM
pfsantos's Avatar
Quoted: 133 Post(s)
Here:
Paul (Paulo Santos)
Youtube:
pfsantos is offline
post #7 of 9 (permalink) Old 04-25-2019, 11:55 PM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
I have replaced it. It was not so complicated job. Few standard tools and that is it.
post #8 of 9 (permalink) Old 04-26-2019, 11:47 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 520 Post(s)
Did you take any photos to help the other B members here..?
DEVOURS is offline
post #9 of 9 (permalink) Old 04-27-2019, 02:55 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
Nope. I’m so sorry. It is 2 hours job, but when I start to work it extends to 2 days. I had to replace protective rubber on shock absorber too. Btw it is not so complicated job,only corroded bolts could make a big problem.
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
My solution for replacement of the lower SLS joint NZJay W140 S-Class 31 05-29-2019 03:40 AM
W163 front lower ball joint replacement Chris Souch W163 M-Class 1 03-03-2019 09:28 PM
W124 Ball Joint replacement (my experience) radioguy123 W124 E,CE,D,TD Class 3 09-17-2015 02:49 AM
Ball joint replacement s430 wroding W220 S-Class 1 03-21-2015 04:45 AM
Ball joint (tie rod) Replacement speed9644 W124 E,CE,D,TD Class 11 02-05-2015 01:32 PM
