Led stripe for cup holder - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 04-15-2019, 01:40 PM Thread Starter
Breadford's Avatar
Date registered: Dec 2018
Vehicle: 2006 B180
Quoted: 13 Post(s)
Hello, I bought this 3 SMD blue led strip for cup holder. Where is the easiest connection spot for that. I planned to use cigarette lighter.
Breadford is online now
post #2 of 14 (permalink) Old 04-15-2019, 05:17 PM
MB•David's Avatar
Date registered: Oct 2013
Vehicle: A200 Sports Coupé C169 2006
Quoted: 193 Post(s)
Yes, either front or rear power socket is the best.
I hard-wired my drinks holder light to the rear power socket:
found a better pic:
or two (this is closer to how it appears):
David
MB•David is online now
post #3 of 14 (permalink) Old 04-15-2019, 09:53 PM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 13 Post(s)
Nice. I have ordered blue led t5 for lighter too.
MB•David likes this.
post #4 of 14 (permalink) Old 04-15-2019, 11:11 PM
MB•David's Avatar
Quoted: 193 Post(s)
Thanks
Let me know if you need WIS files on removal of the lower centre console and rear panel.
David
post #5 of 14 (permalink) Old 04-16-2019, 02:55 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 13 Post(s)
I have done that earlier, I hope it will be easy
post #6 of 14 (permalink) Old 04-16-2019, 08:46 AM
MB•David's Avatar
Quoted: 193 Post(s)
Yes, very straightforward - start with the chrome gear surround, just pry it up with your fingers, going around the circumference, then push up the rear end of the lower console, from each side, and then it's pretty obvious...
David
post #7 of 14 (permalink) Old 04-16-2019, 09:20 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 13 Post(s)
DIY job is done. Total cost: 10 euro cents. It was easy. I’m not so tidy, but it is cool.
ID:	2504892   Click image for larger version
ID:	2504894   Click image for larger version
post #8 of 14 (permalink) Old 04-16-2019, 12:56 PM
MB•David's Avatar
Quoted: 193 Post(s)
Great! Very nice effect with a water bottle.
Now you need to start thinking of door handle lights and footwell lights. Blue, of course
Breadford likes this.
David
post #9 of 14 (permalink) Old 04-16-2019, 01:45 PM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 13 Post(s)
Personally I don’t like door handle light, but footwell is a good idea. Could you give me some advices about footwell light?? Where is connection spot, etc.
post #10 of 14 (permalink) Old Yesterday, 09:33 AM
MB•David's Avatar
Quoted: 193 Post(s)
Footwell lights weren't pre-wired in my car, but the cut-outs were there (not sure if this is universal across the range or Avantgarde thing), so I bought a pair of OEM footwell lights, fitted blue LEDs and wired them myself to be permanently on. That was I think three years ago and no problems so far (as in - I didn't have to replace the LEDs yet).
I considered a couple of different bulbs:
I had to make sure the "bulb" won't rotate (especially the one under the glove box), so made these clips from an old store plastic card:
Modified OEM footwell lights (only connector was modified):
This was taken three years ago, before the carbon fibre, steering wheel, instrument cluster and head unit upgrade:
In reality, the lights are much less prominent ...
As to the door handle lights - I like them
I used tiny 3mm diffused LEDs, and it is almost impossible to actually see the light source (unless one looks from about the steering wheel position facing back):
These are actuated on 58d signal, so only come on with the rest of instrument lights. The install is a bit more complicated, than the footwell lights though...
I think it works together well enough:
pfsantos, DEVOURS and Breadford like this.
David
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Cup Holder to Replace Cassette Storage subman576 R129 SL-Class 4 12-27-2017 03:05 AM
M103 Spark Plug Wire Holder (HOW TO) Takumi12 W124 E,CE,D,TD Class 7 12-18-2016 06:50 PM
w210 wagon third brake light replacement Diaster thejoebear W210 E-Class 2 05-20-2016 09:05 AM
LED Taillight upgrade on pre-facelift SURPRISES 93SoCal400E C209/A209 CLK-Class 4 01-06-2016 10:18 PM
House charges Holder with contempt of Congress NEOKEN Off-Topic 5 06-28-2012 08:22 PM
