2355-002: EGR Control Air Mass Too High - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-29-2019, 05:18 AM Thread Starter
Date registered: Mar 2019
Vehicle: 2005 B180 CDI CVT
Quoted: 7 Post(s)
B180CDi 2005 85,000 miles:
The car had rough idle, like 'huffing' sound. My understanding was this could be a leaky injector seal as it's common with Mercedes diesels. However, on removing the injector well and to my suprise it was clean like from factory. There were no codes present apart from the parking sensors.
Although, the egr valve was clean, I did also superficially clean the mixing chamber with brush. On asssembly, now I get the above code 2355-2 with engine check light, but idle is stable and there's no 'huffing' sound.
So I decided to strip and clean the mixing chamber, throttle and the intake port.
The code is still present . The vacuum pipes have been changed and both pressure converters are new. I have tested the egr valve with a vacuum pump and opens fine, however the valve is slightly sticky when releasing vacuum. Furthermore, at the time I should have checked the egr pipe to the cooler for blockage . The rough idle I believe is related to the intake flaps or the motor since it's heavily coked up with carbon.
I also noticed, the vacuum lines to the vacuum tank in the air filter box were broken so I replaced the air filter box.
Before I throw money towards a new egr valve, I would love to clean the intake manifold and flaps. Not sure if this is possible without dropping the engine.
W245207 is offline
post #2 of 7 (permalink) Old 03-29-2019, 06:19 AM
pfsantos's Avatar
Date registered: Nov 2005
Vehicle: '83 W123 200 '98 E200 Kompressor (both Euro-spec., 200 in Portugal, E200 Now in Canada!), '08 B200
Quoted: 133 Post(s)
A rough idle due to the EGR system means exhaust is still making its way to the intake due to a bad sealing at the EGR valve due to carbon deposits. Focus on the area where the valve closes against the exhaust passage. Can you get in there and clean it better?
W245207 likes this.
Paul (Paulo Santos)
Youtube:
'83 W123 200, '98 W210 E200K, '08 W245 B200
* Feel free to PM me if needed *
pfsantos is online now
post #3 of 7 (permalink) Old 03-29-2019, 07:18 AM Thread Starter
Quoted: 7 Post(s)
When it's idling rough, the egr duty cycle is at 95%. However, with 2355-2 code the egr duty cycle is at 5%. This is pretty much similar to what Dave2302 experienced with the sprinter.
The valve is clean, and other bits are pretty spotless. Looking around on other forums, the issue is most likely related with the intake flaps (#120)
W245207 is offline
post #4 of 7 (permalink) Old 03-29-2019, 10:50 AM
Breadford's Avatar
Date registered: Dec 2018
Vehicle: 2006 B180
Quoted: 21 Post(s)
I have got rid of rough idle with cleaing Egr valve and pre intake manifold. I’ve done that while changing thermostat and one glow plug.
W245207 likes this.
Breadford is offline
post #5 of 7 (permalink) Old 03-29-2019, 11:29 AM Thread Starter
Quoted: 7 Post(s)
Originally Posted by Breadford View Post
I have got rid of rough idle with cleaing Egr valve and pre intake manifold. Iíve done that while changing thermostat and one glow plug.
Is that the mixer housing (#165)?
W245207 is offline
post #6 of 7 (permalink) Old 03-29-2019, 01:30 PM
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 21 Post(s)
Idk what is a real name of that but on picture it is #165 and #10. It was so grimy (dirty).
W245207 likes this.
post #7 of 7 (permalink) Old 05-18-2019, 06:38 AM Thread Starter
Quoted: 7 Post(s)
UPDATE [Solved]:
A few weeks ago I replaced the EGR valve which didn't make any difference. However, I replaced the plastic Y branch fitting with a new rubber version (A6030780045)
This seems to have solved the 2355-2 code and I'm getting boost now. On closer inspection of the old Y connector, there is a fine crack on both openings.
MBēDavid likes this.
W245207 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Bad preformance Arotished R170 SLK-Class 13 06-04-2008 09:12 AM
Rear Wheel Bearing Nightmare Ii Dman123 W201 190-Class 10 01-23-2007 12:48 PM
Mass Air Flow Sensors pmetzger For Sale/Wanted/Trade/Giveaway 0 11-20-2006 02:09 PM
