Strange sound - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-01-2019, 11:50 AM Thread Starter
Breadford's Avatar
Date registered: Dec 2018
Vehicle: 2006 B180
Quoted: 22 Post(s)
Strange sound
Hello.
Last few days I started hearing strange sound from the left side (driver's side). It is happening when the engine is cold and when I turn the steering wheel left or right. When I put in P position, it goes away. It only lasts for first 2-3 mins. Here is a video, with a same sound, I found online:
Breadford is online now
post #2 of 11 (permalink) Old 03-01-2019, 11:52 PM
pablo_can's Avatar
Date registered: Dec 2017
Vehicle: w245 2006
Quoted: 51 Post(s)
I think you should first check cv joints. then shock mounts.
pablo_can is online now
post #3 of 11 (permalink) Old 03-02-2019, 01:17 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
I have changed left cv joint 10k kms ago. But It is a cheap ITN cv joint.
post #4 of 11 (permalink) Old 03-02-2019, 06:45 AM
forrera's Avatar
Date registered: Jan 2012
Vehicle: A180 CVT, A170, A190, B200
Quoted: 54 Post(s)
The sound in the video is coming from the oil pump in the CVT, drawing air as well as oil.
Add half of liter of CVT fluid to the transmission.
MB•David likes this.
The day your mechanic tells you to get rid of your a class is the day you should get rid of him.
forrera is online now
post #5 of 11 (permalink) Old 03-02-2019, 08:06 AM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
It is present only when engine is cold, after start, first 2 mins. When car is in P, everything is normal, without sound. Which oil to use, and where is hole for filling??
post #6 of 11 (permalink) Old 03-02-2019, 01:43 PM
MB•David's Avatar
Date registered: Oct 2013
Vehicle: A200 Sports Coupé C169 2006
Quoted: 207 Post(s)
These files should be useful.
File Type: pdf W169 WIS Filling automatic transmission with fluid.pdf (183.8 KB, 16 views)
File Type: pdf W169 WIS Oil pump component description.pdf (95.1 KB, 11 views)
File Type: pdf W169 WIS Remove_install automatic transmission oil pan.pdf (208.0 KB, 16 views)
File Type: pdf W169 WIS Pulley set component description.pdf (88.7 KB, 11 views)
File Type: pdf W169 WIS Remove_install oil pump up to 4-07.pdf (105.6 KB, 18 views)
File Type: pdf W169 WIS Remove_install oil pump from 4-07.pdf (245.5 KB, 16 views)
File Type: pdf W169 WIS Remove_install oil filler pipe for automatic transmission.pdf (132.9 KB, 16 views)
File Type: pdf W169 WIS Separate_connect transmission oil line.pdf (183.0 KB, 15 views)
File Type: pdf W169 WIS CVT transmission oil (ATF, specification 236.20.pdf (12.5 KB, 22 views)
File Type: pdf W169 WIS Check oil level in automatic transmission and correct if necessary CVT.pdf (146.0 KB, 21 views)
dinraa likes this.
David
MB•David is offline
post #7 of 11 (permalink) Old 03-02-2019, 06:18 PM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
Thanks 😃
post #8 of 11 (permalink) Old 03-28-2019, 02:56 PM Thread Starter
Breadford's Avatar
Vehicle: 2006 B180
Quoted: 22 Post(s)
Is it good to fill up CVT with Comma AQCVT fully synthetic oil?? Idk which oil is now in my CVT. Is it ok to add this comma oil ??
post #9 of 11 (permalink) Old 03-28-2019, 03:30 PM
MB•David's Avatar
Quoted: 207 Post(s)
There's a file above with full spec of MB CVT oils (236.20) - if this is not on the list, I'd stay clear.
Here's the MB branded one, in case you're looking:
https://www.ebay.co.uk/itm/Genuine-M...0/112799650834
David
MB•David is offline
post #10 of 11 (permalink) Old 03-28-2019, 09:39 PM
Gammelvind's Avatar
Date registered: Jul 2016
Vehicle: 2008 B170
Quoted: 31 Post(s)
Down load the BeVo app onto your phone or ipad, this has a full list of MB approved fluids.
Does the fluid comply with MB 236.20 for MB cvt oils, if it doesn’t say that or says similar to then move on.
Gammelvind is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
2009-C230 Inerior Noises and Panel Flex Sounds 2009C2304MATIC W204 C-Class 18 07-29-2016 11:30 AM
2010 E350 4Matic - Strange whining sound (Solved: Air Pump failure w212) jseah W212 E-Class 19 04-25-2014 08:17 PM
Strange sound isarescu R170 SLK-Class 4 05-31-2011 02:50 PM
New strange sound underneath car Zaxler W210 E-Class 14 04-26-2010 12:07 AM
strange engine sound - together with strange smell under hood? quepao W163 M-Class 2 01-23-2006 08:31 AM
