Coolant Flushing - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-18-2019, 08:13 AM Thread Starter
Date registered: Mar 2014
Quoted: 99 Post(s)
Coolant Flushing
I'm slowly approaching the 240,000 km mark and besides my timely oil change, the coolant system needs to be flushed (according to owner's manual).
At this point, is it worth doing? Or is it better to wait for a cooling system related repair and to start fresh?
Otherwise everything is fine. I'm sure my mechanic will probably say to hold off. I guess depending on the molecular condition of the fluid may determine if it needs a refresh.
As an aside, but related, I've heard about automatic transmissions, from various sources, that flushing it with new fluid can make it worse. I know, they are two different systems, but could new coolant dislodge sludge build up or something similar. I think that would be reaching.
Moved On To Nissan
Road_Ghost is offline
post #2 of 6 (permalink) Old 02-18-2019, 10:41 AM
DEVOURS's Avatar
Date registered: Dec 2006
Vehicle: 2006 B 200 .....& Audi A6..
Quoted: 514 Post(s)
My B coolant shows that it's good for 15 years and xxx # of kilometers..
My only hope is that I can renew with the exact same 15 year coolant that came with my B....My kms are still too low..but the years are now making it due..
Does anyone here know how long the new B Class coolant is good for ?
DEVOURS is offline
post #3 of 6 (permalink) Old 02-18-2019, 10:56 AM
Breadford's Avatar
Date registered: Dec 2018
Vehicle: 2006 B180
Quoted: 20 Post(s)
Hello. My suggestion is firstly to do repair job. This is first time to hear about flushing and automatic problem.
In few days I'm changing thermostat so I will completly change cooling fluid.
Breadford is offline
post #4 of 6 (permalink) Old 02-18-2019, 03:53 PM Thread Starter
Quoted: 99 Post(s)
I was referencing that some automatics (not the CVT like B200) had the need for grit in the old fluid to prevent slipping. These are most likely for the high mileage/worn transmissions. This can be because the new fluid has more lubricating qualities. Regular maintenance and ideal operating temperatures are key for any transmission longevity.
Breadford likes this.
Moved On To Nissan
post #5 of 6 (permalink) Old 02-20-2019, 03:29 AM
MB•David's Avatar
Date registered: Oct 2013
Vehicle: A200 Sports Coupé C169 2006
Quoted: 207 Post(s)
I was asked (and replied) via PM, but I also thought it might be useful for everyone to have these WIS files on thermostat replacement and coolant draining (for 266 engine):
File Type: pdf 245 Remove_install coolant thermostat.pdf (120.2 KB, 14 views)
File Type: pdf 245 Removing_installing the air intake tube.pdf (203.8 KB, 9 views)
File Type: pdf 245 Remove_install ME-SFT [ME] control unit.pdf (236.0 KB, 12 views)
File Type: pdf 245 Pour in coolant and bleed cooling system.pdf (174.1 KB, 13 views)
File Type: pdf 245 Inspect cooling system for leaks.pdf (192.4 KB, 17 views)
DEVOURS and Breadford like this.
David
MB•David is offline
post #6 of 6 (permalink) Old 02-20-2019, 03:32 AM
MB•David's Avatar
Quoted: 207 Post(s)
Some more:
File Type: pdf 245 Service Information_ Check function of coolant thermostat.pdf (71.4 KB, 17 views)
DEVOURS likes this.
David
MB•David is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W245 B-Class
Coolant flush question - don't mix coolants? zoomzoomie W140 S-Class 24 06-24-2017 08:39 AM
98 C280 Coolant Level Light Tofuti W202 C-Class 1 06-25-2012 07:02 AM
Flushing the engine and coolant vvrjrlaw W140 S-Class 2 04-07-2012 11:15 AM
anyone tried Prestone/other 5 yr Coolant (instead of the Benz Coolant) heartmd W140 S-Class 6 11-17-2007 09:28 AM
190E Coolant light constantly on... 190Evoluzione W201 190-Class 10 03-20-2007 04:31 AM
