WEISTEC ECU Upgrade - - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-05-2018, 11:10 AM Thread Starter
PKariCL600's Avatar
Date registered: Nov 2006
Vehicle: 2015 S550 Sport ; 2003 CL500 Sport Pkg ; 1999 S500 ; 1999 CL600 **RIP**
Anyone done this to their W222 S550 yet?
Any other tune/ECU suggestions/experiences?
My 15 S550 is about to come out of warranty and I'd like to juice it up a bit!
Thanks everyone!
PKariCL600 is offline
post #2 of 7 (permalink) Old 12-18-2018, 10:34 AM Thread Starter
PKariCL600's Avatar
anyone?
post #3 of 7 (permalink) Old 12-18-2018, 08:24 PM
Supreme Sandwich
Josh's Avatar
Date registered: Aug 2010
Vehicle: '84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
Location: San Antonio, Texas/Gulf Breeze, Florida/Neustadt a.d. Aisch, Deutschland
Quoted: 712 Post(s)
Looked around the web for anything, but nothing so far.
Stock HP for a 2015 S550 is listed at around 449HP, so $1500 nets you an additional 91HP, which runs you about $16.48 per 1HP. Relatively speaking, that's not all that expensive.
Given base HP of 449, and we'll say you got the car from the dealer for $91,000 out the door before taxes (you may have done better, you may have done worse, this is just an example) which is around $202.67 per 1HP.
RENNTech has a tune as well, for $2700, claiming the same 540HP, but reduced torque at 705lb-ft.
They state the factory numbers are underrated (they list 429HP and 516lb-ft, to the crank, as the stock ratings from MB) and actually got 474HP @5500RPM and 566lb-ft @ 2800-3900RPM when measured at the crank for a stock 4.7 BiTurbo V8.
At the crank, RENNTech measures 540HP @5500RPM and 705lb-ft @3700RPM with their ECU tune. According to them, this translates to 448HP @5500RPM and 585lb-ft to the wheels for 4Matic models. Based on the difference between crank and at the wheels, this is a 17% loss due to the 4Matic drivetrain. I'd imagine the loss to be less to a RWD car, but not by much.
At any rate, this translates to 66HP gained with the RENNTech tune, which translates to $40.90 per 1HP. Still reasonable compared to what you payed per HP for the base car, but almost double (I know I said it's ~$16 per 1HP for the Weistec tune, but I'll get to the real cost per HP for the Weistec unit down below) the cost per HP when compared to the Weistec unit. That said, RENNTech is a very well-known name and intimately familiar with MBs. I would trust their dyno sheets and their product. However, Weistec is also well-known, and if you're currently in CA with the car, local to you. They could do the install for you, even.
Using the stock crank numbers from RENNTech, we'll say your car makes 474HP at the crank, and you get the 540HP tune. That's an increase of 66HP, which when you figure in $1500 for the tune, comes out to $22.73 per 1HP from the Weistec tune. $4 more than the $16.48 that was calculated at a 91HP gain based on a 449 stock HP rating at the crank, but still almost half the cost of RENNTech.
There are other tuners out there who provide tunes, but both of these are big names that are local here in the US, one of which is even local to you.
I'd give the Weistec tune a try and post up your results. Know many who have used their tunes in BMWs who are happy with the results.
I hope all of this made sense.
'85 Euro 190E 2.3-16
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
'98 Dodge Durango SLT+ 5.9L Magnum V8
'96 Ford F350 7.3 PSD
~Josh
Josh is offline
post #4 of 7 (permalink) Old 01-02-2019, 12:45 PM Thread Starter
PKariCL600's Avatar
Josh thank you sir!!
I appreciate all the info and yes it makes sense!
post #5 of 7 (permalink) Old 01-04-2019, 07:49 PM
Supreme Sandwich
Josh's Avatar
Quoted: 712 Post(s)
You're welcome! Glad I could help.
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
~Josh
Josh is offline
post #6 of 7 (permalink) Old 07-23-2019, 11:27 PM
Date registered: Jul 2019
Go renntech. You pay for the name reputation and research. They have been around the longest and are the best in the business. And yea there tune turned a already fast car... into a “ 4 door rocket ship”
smokindave likes this.
S550Renntech is offline
post #7 of 7 (permalink) Old 07-29-2019, 10:26 AM
smokindave's Avatar
Date registered: Jan 2011
Vehicle: 1996 Mercedes Benz S500 sedan,1997 S500,2012 s550
Quoted: 2 Post(s)
About ten days ago I got my RENNtech tuner installed on my 2012 s550.
540 hp and 705 lbs torque.
Iím very happy with the tune and love the way the car drives now.
If you are like me and love to drive this tune will make your car run the way it should of from the factory.
Iím sure Iím getting better fuel mileage because when you drive normal you barely engage the throttle and she takes off.
This weekend Iíll let you know how I do racing a friend and his souped up CTSV Cadillac.
I can honestly say it pulls as hard or maybe harder than my Corvette.
Just do it!
smokindave is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W222 S-Class
