All dynamic seats stopped working - the pump? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-04-2019, 08:15 PM Thread Starter
Date registered: Sep 2006
Vehicle: '07 S600, '00 E320 Wagon, other
Quoted: 21 Post(s)
I'm thinking that the error I posted in another thread is not the main problem, since ALL the seats stopped working and the error is only for the Driver Seat.
(Error 9200 Driver's Module Carrier for the Backrest is Defective - I'm thinking it's part number 221-910-22-75 )
I clear the error, does not come back. I try to inflate the individual cushions/bladders with the Star - none inflates, message "Failed for unknown reasons". All the bladders in all seats give the same results (Star connects to all seats).
I've also updated the s/w in the driver seat (often s/w is buggy in 2007 like not remembering the lumbar support and newer versions fix multiple problems), no change.
I try to connect to the pump - Star fails to connect (multiple times). So I'm guessing the pump module in the trunk is bad. But all soft closing of the doors and central power locking is working - my understanding is that the pump is shared between the seats and the door locks? So the pump must be working in some way. Also, the Star does not show any pump errors!
I'm thinking the 9200 error is not the main problem, maybe the pump is. What to test/how to move from here if ALL seats don't work? How to definitely determine if the pump is good or bad?
thanks
George993 is offline
post #2 of 5 (permalink) Old 07-05-2019, 03:28 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 453 Post(s)
George993, you may be onto something with the pump. While the following writeup will not help with the W221 pump, it does show that the pse pump in the W220 must be programmed for its functions. See https://www.benzworld.org/forums/w22...ft-self-2.html
You are already way ahead of me in your troubleshooting skills, but this reference just shows you may be on the right track.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 5 (permalink) Old 07-05-2019, 04:37 PM Thread Starter
Quoted: 21 Post(s)
Thanks Skylaw. BTW, meanwhile I've learnt that the doors on W221 are electrically operated (despite multiple listings on ebay for 2007-2009 air pump for BOTH doors and seats). Which means they are not related to seat operation.
So I've ordered a replacement pump and will give it a try - at least unlike all the seat internals it looks like an easy replacement :-)
thanks
post #4 of 5 (permalink) Old 07-06-2019, 03:55 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 453 Post(s)
The soft close feature of the doors on the MY '10 and '13 are certainly electrically operated. I can't speak to earlier.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #5 of 5 (permalink) Old 07-14-2019, 06:12 PM
Date registered: Jul 2015
Vehicle: 1997 C280
Quoted: 20 Post(s)
My 2008 door latch are electrically operated. Here is the proof and more on this issue later:
ID:	2527818   Click image for larger version
ID:	2527820   Click image for larger version
Jagpilot is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
