Car swilling after setting up - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-07-2019, 12:10 PM Thread Starter
Date registered: Aug 2018
Vehicle: 2008 S550
Exclamation Car swilling after setting up
I have s550 2008 after setting up for couple months (3) I boost car off n as it was running it started to squealing for a couple minutes then stop n start again then it would cut car off also my abs light and esp light on in the dash that was not on when I parked car can someone help me with this issue
Nucor31 is offline
post #2 of 11 (permalink) Old 06-07-2019, 12:11 PM Thread Starter
Vehicle: 2008 S550
Oh it's not a belt its coming from passenger side of car
Nucor31 is offline
post #3 of 11 (permalink) Old 06-07-2019, 12:34 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 447 Post(s)
First, a little more care in posing your question would be helpful to those of us trying to understand what you are asking. As I understand the question, you let the car sit for 3 months, then started it with a battery booster; an intermittent squeal began somewhere on the passenger side of the car (engine compartment, or elsewhere?), and your ABS and ESP lights came on after it started. By "swilling" I suspect you meant "squealing."
The ABS and ESP lights will come on if you battery has been allowed to run down or has been disconnected. See the "RESETS" link in the "General Info" portion of the DIY & FAQs in the "stickies," in the blue backgrounded portion at the upper part of the first forum page. The reset is very simple, but I want to point you to a resource that will be helpful during your ownership.
We could speculate on belts, pumps, squealing shafts or any number of things; a bit more precision on the origin of the squealing would be helpful.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #4 of 11 (permalink) Old 06-08-2019, 01:17 PM Thread Starter
Vehicle: 2008 S550
Car squealing
Thanks Skylar I went yesterday and retryed the car squealing has stop but the other issue is I replaced the rear strut before that I had a flat n when I changed the tire I let car back down it went all the way down to the tire n in cat it says car to low so I replaced the strut and it will not air the struts up all 4 are sitting down I can hear air trying to go n rear strut but will not lift up
Nucor31 is offline
post #5 of 11 (permalink) Old 06-09-2019, 05:21 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 447 Post(s)
Apparently your airmatic pump is still working, but you have a leak in the system.
You might try raising the car with the engine off; with the weight off the struts but with the wheels touching the ground, start the car. This will inflate the struts (hopefully they are not damaged). Then lower the car. You may still have the leak, and the soapy water test (spraying soapy water especially at joints in the tubing) may help to find it.
You could also have a bad control valve for that rear strut. Check the DIY & FAQs for more on the airmatic suspension.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #6 of 11 (permalink) Old 06-09-2019, 12:37 PM Thread Starter
Vehicle: 2008 S550
Thanks Skylar I'll try when I get off also I forgot to mention was that the car is sitting down in front n back will that control valve do that
Nucor31 is offline
post #7 of 11 (permalink) Old 06-10-2019, 11:38 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 447 Post(s)
That the car is down front & back may be more to failure to at least partially inflate the struts before fully lowering the car back onto them.
And who is this Skylar? Not me.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #8 of 11 (permalink) Old 06-16-2019, 06:04 PM Thread Starter
Vehicle: 2008 S550
I'm sorry Skylaw but I had to put a fuse in it the front cam up but the back didn't come up sounds like you can here air going to the struts but nothing think the leveling switch has broke just asking
Nucor31 is offline
post #9 of 11 (permalink) Old 06-17-2019, 11:03 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 447 Post(s)
If the rear is down on both sides and the front is up, it is entirely possible the rear ride height ensor is either broken or assembled incorrectly. It is not uncommon, after work has been performed, for the link to be left unattached, and that would certainly cause such a problem.
BTW - and perhaps late, and while it doesn't really address how to fix the ride height sensor - this might be some help in the future. HERE
dlafever likes this.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #10 of 11 (permalink) Old 06-19-2019, 10:38 AM Thread Starter
Vehicle: 2008 S550
Ok thanks I'll order one today I forgot I think I hear air from both struts sounds like its going in the struts but sounds like I hear air from middle of car but the axle area
Nucor31 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
