Fixed the Washer Fluid Indicator - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-01-2019, 12:40 AM Thread Starter
Shadly1's Avatar
Date registered: May 2019
Vehicle: 2007 S550
Quoted: 6 Post(s)
I fixed the Washer Fluid Indicator and it was a piece of cake! It was telling me that I needed to add washer fluid even after I did.
dlafever likes this.
Shadly1 is offline
post #2 of 4 (permalink) Old 06-01-2019, 05:52 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 447 Post(s)
Thanks, Shadly 1. Very interesting "solution." Added to the DIY & FAQ in the "Electrical" DIY section.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #3 of 4 (permalink) Old 06-01-2019, 08:54 PM
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Quoted: 109 Post(s)
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
So thinking about my regimen for washer fluid, I realized why I don't have this issue.
Having decrusted and degunked a ton washer nozzles over the 30 years I've been stricken with the Benz Bug, I exclusively use distilled water and a squirt of Dawn (sodium sulfate and more!) dishwashing liquid for my washer fluid.
So, what I'm after here is instead of dissolving salt you can just give it a squirt of soap! Usually when I get the low fluid warning I'll stop by a drug store and pick up a gallon of distilled water and just use the little bottle of Dawn I have in the trunk.
Mind you all of this works because I live where it rarely freezes. When I did leave where it would freeze in the winter I just added rubbing alcohol to lower the freezing point of the water.
Nice video! Thanks for taking the time to share.
dlafever is offline
post #4 of 4 (permalink) Old 06-01-2019, 09:26 PM Thread Starter
Shadly1's Avatar
Vehicle: 2007 S550
Quoted: 6 Post(s)
Hmm, it never occurred to me that there were minerals in dish soap. My brain jumped to salt or baking soda and I was out of baking soda. I also have a liquid mineral supplement I wanted to try. I am curious to come up with a "borderline" mix and measure conductivity.
I'm most likely in the exact same climate as you so I could get away with the soap trick.
Shadly1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
