2007 S-550 W221 - Engine Oil Change and Air Filter repalcement - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 05-30-2019, 02:38 PM Thread Starter
Date registered: Nov 2005
Vehicle: 1997 E-420, 2001 E-320, 2007 S-550, 2009 E-350
Quoted: 26 Post(s)
Send a message via Yahoo to hadam
Hello all. I will be doing oil service first time on my 2007 S-550, most of the time it was done at Dealer or Indy shop.
I have few questions.
How many quarts of oil my 2007 S-550 takes? I believe my engine is M273 (273961 30 101684). Attached is data card of my car, I ran the VIN decoder.
Also, I like to change engine air filters. Is there any DIY for engine Air filters replacement?
Any feedback will be appreciated.
2001 MB E-430 Gone- Totaled
2009 MB E-350
2001 MB E-320
2003 MB CLK-320 Cabriolet
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #2 of 14 (permalink) Old 05-30-2019, 10:36 PM
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Quoted: 108 Post(s)
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
HADAM!
The WIS procedures state 8.5L for engine oil and filter change. I usually put right about that amount in and the level is always between the low/high marks on the dipstick.
For oil, I recently switched to Liqui Moly 2332 Leichtlauf High Tech 5W-40 Engine Oil because I live in the desert and we just don't get cold temps here. It's on the approved list as is Mobil1 0w-40. You can get either for about $35 for 5L.
dlafever is online now
post #3 of 14 (permalink) Old 05-31-2019, 10:54 AM Thread Starter
Quoted: 26 Post(s)
dlafever, thank you for your reply on oil capacity of 8.5 quarts for 2007 M273 engine W221 S-550.
Regards to engine air filter, do you have any info on it? Is there is any DIY for it or you can direct me to some post on it.
Thanks in advance for your support.
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #4 of 14 (permalink) Old 05-31-2019, 11:13 AM
dlafever's Avatar
Quoted: 108 Post(s)
Glad to help! For the oil it is Liters (L) not Quarts. In the end I use about 8.5L each change.
The air filter is super easy, and yes there is a DIY from the W212 forum. The procedure for the M272 (V6) and M273 (V8) engines is quite similar.
https://www.benzworld.org/forums/w21...er-change.html
post #5 of 14 (permalink) Old 05-31-2019, 04:03 PM Thread Starter
Quoted: 26 Post(s)
dlafever, thank you for your reply. I understand now. I have done engine air filter replacement on my 2009 E-350 W211. My 2009 E-350 has engine M272.
Thank you, I will follow same for my 2007 S-550 W221 that has engine M273.
I am all good, appreciate all your support.
Below some photos of my E-350 and S-550. V6 and V8.
ID:	2517298   Click image for larger version
ID:	2517300   Click image for larger version
ID:	2517302   Click image for larger version
dlafever and Shadly1 like this.
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #6 of 14 (permalink) Old 05-31-2019, 08:28 PM
dlafever's Avatar
Quoted: 108 Post(s)
Great stable of Benz you have there! I've got a similar collection with the S550, E350 and ML320 (we'll see how long this one lasts in the hands of my youngest son. )
post #7 of 14 (permalink) Old 06-01-2019, 07:41 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 377 Post(s)
For the record...
dlafever, Skylaw and Shadly1 like this.
konigstiger is offline
post #8 of 14 (permalink) Old 06-03-2019, 08:48 AM Thread Starter
Quoted: 26 Post(s)
konigstiger, thank you so much for the PDF information, I do appreciate the time you spend on this forum to help others.
These PDF are going into my Cloud archives. I was not 100% sure about the drain plug torque, but these PDF information confirmed the 30 Nm.
I really appreciate all the support I have been getting on this forum.
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #9 of 14 (permalink) Old 06-03-2019, 02:24 PM
Shadly1's Avatar
Date registered: May 2019
Vehicle: 2007 S550
Quoted: 6 Post(s)
Oh the timing!!! I have some new air filter elements on their way to me right now and had no idea how to install them.
What's up, Arizona peeps?
Shadly1 is offline
post #10 of 14 (permalink) Old 06-09-2019, 07:09 AM Thread Starter
Quoted: 26 Post(s)
dlafever and konigstiger. Happy Sunday. Yesterday I was able to perform oil service for first time on my 2007 S-550. All went well. It took me about an hour to perform the service.
My 2007 S-550 took 8.5 quarts, the dip stick was showing between min and max. May be 1/2 quarts was still left in the oil filter housing etc.
All good. I will check the oil level again next weekend, if its come down then I will add the 1/2 quarts. Other wise, all good.
Thank you both (dlafever and konigstiger) for all your excellent support on this forum. You saved me about $400 and saved me from headache you get when are dealing with German shop or dealer.
ID:	2519046   Click image for larger version
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
