Passenger Side External dipping Mirror - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 05-25-2019, 03:38 PM Thread Starter
Date registered: May 2008
Vehicle: 2000 W220 S500 replaced by S500 W221 MY10 & 2007 W209 CLK280
Quoted: 30 Post(s)
Originally Posted by konigstiger View Post
Have passenger side door control unit software checked i.e.: reinitialize, update using SDS I believe the path is: Control units - Seats and Doors - Door control module front left (right) - Control unit adaptations - Control module programming.
Thanks konigstiger
I will have my Indi check that out.
Regards
Ralph Davies
(purdiemerc)
Sydney
Australia
PurdieMerc is offline
post #12 of 19 (permalink) Old 05-26-2019, 05:50 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 444 Post(s)
Originally Posted by PurdieMerc View Post
Thanks Warren
Can you get your rear wheel in view ?
Yes.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #13 of 19 (permalink) Old 05-29-2019, 11:38 PM Thread Starter
Quoted: 30 Post(s)
Hi
I had my Indi look at it.
All settings were correct but he could not update the software as he did not have access to the Mercedes site.
I will need to take it to the Stealer to have it re programmed if that is needed ?
Regards
Ralph Davies
(purdiemerc)
Sydney
Australia
post #14 of 19 (permalink) Old 05-30-2019, 04:56 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 444 Post(s)
I think we have taken this as far as it can go at this point; check your dealer.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #15 of 19 (permalink) Old 05-30-2019, 04:01 PM Thread Starter
Quoted: 30 Post(s)
Thanks Warren
I will try another Indi first then the next step is the stealer.
One more Question, when you select the passenger side mirror does the indicator light on the switch stay on (Latch), if it doesn't does the mirror dip when you select reverse or do you need to select the mirror again first ?
Regards
Ralph Davies
(purdiemerc)
Sydney
Australia
post #16 of 19 (permalink) Old 05-31-2019, 05:46 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 444 Post(s)
The way mine works is that in order to have the passenger mirror dip, I must leave that mirror selected in the door control panel. The light in the button is off when the ignition is off. Upon restarting, the light is off until the car is put into reverse, when it illuminates and the mirror repositions. After that, the light remains on until the car is placed in drive and the mirror repositions to normal - at that point it goes out.
Of course, if the passenger mirror button does not remain selected, none of this happens.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Last edited by Skylaw; 06-01-2019 at 04:32 PM. Reason: Corrected an error (bold, underlined)
Skylaw is offline
post #17 of 19 (permalink) Old 05-31-2019, 03:22 PM Thread Starter
Quoted: 30 Post(s)
Thanks
Warren
My button light goes off after about 10 seconds and stays off even when reverse is selected. This is a very interesting difference and will possibly provider pointer to what the problem is, thanks.
Maybe that indicates a faulty switch, or maybe there is a difference between the MY10 and your MY13.
I would be interested to hear from another MY10 owner on this ?
I will be taking it to the other Indi next week and if he can't fix it to the Stealer the following week.
I will keep you all posted on how it pans out.
Thanks for the Help
Regards
Ralph Davies
(purdiemerc)
Sydney
Australia
post #18 of 19 (permalink) Old 06-01-2019, 05:47 AM
Skylaw's Avatar
Vehicle: 2013 S550
Quoted: 444 Post(s)
My own '10 worked the same as my '13. You just need to get it to someone who can analyze it properly.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #19 of 19 (permalink) Old 06-01-2019, 03:09 PM Thread Starter
Quoted: 30 Post(s)
Thanks Warren
Planned for next week.
Regards
Ralph Davies
(purdiemerc)
Sydney
Australia
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
Passenger Side Mirror (Am I the Only One Bugged by this?) Mirv R/C107 SL/SLC Class 5 05-11-2017 12:43 PM
Passenger side view mirror replacement jfeels W140 S-Class 3 09-06-2011 02:59 PM
Passenger side mirror question Jim MB R/C107 SL/SLC Class 5 08-13-2008 11:03 AM
passenger side mirror question stebro R171 SLK-Class 1 04-15-2006 05:15 PM
mistery! passenger side mirror looks different? drbranko R170 SLK-Class 14 02-07-2006 08:17 PM
