Factory procedure to reduce draw on electrical system to disconnect batteries - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-30-2019, 07:52 AM Thread Starter
Date registered: Dec 2017
Vehicle: 2001 210.082 +494, 2008 221.176 +494
Quoted: 8 Post(s)
If you own a 2007 or 2008 W221 and have had to disconnect, specially the rear battery, you may have noticed a significant arc while attempting to get the terminal loose.
There is actually a factory procedure titled "End internal on-board electrical system functions". Although it is only a one page document, and some of the suggestions it recommends likely contradicts what you have learned over several years about leaving the key in the ignition when making changes to the charging system; whether it be disconnecting a battery, jump starting , etc.
Anyway, I have attached a link to the document below so t may be of help to some 2007 and 2008 owners with the Starter Battery under the hood and the large Consumer Battery behind the rear seat.
https://resources.mbdx.us/files/pdf/..._functions.pdf
I hope others benefit from this information.
Thanks!
TiffanyTwisted is offline
post #2 of 11 (permalink) Old 04-30-2019, 08:51 AM
2008CL6's Avatar
Date registered: Jan 2019
Vehicle: 2008 CL 600
Quoted: 6 Post(s)
The link is not working. It says " page not found "
2008CL6 is offline
post #3 of 11 (permalink) Old 04-30-2019, 09:26 AM
PWidge's Avatar
Date registered: Aug 2017
Vehicle: 2007 S550
I get the same error message. Sounds like valuable information, though, so I'm interested in reading it.
PWidge is offline
post #4 of 11 (permalink) Old 04-30-2019, 06:35 PM Thread Starter
Quoted: 8 Post(s)
My apologies for the permissions error. Please attempt access again. I am sure it is frustrating to see a topic you wish to read up about and it is broken!
Beware it is one of the shorter WIS documents you will find - it is not truncated accidentally - it is intentionally short.
Please update this thread if you are able to access the PDF.
Thank you!
dlafever likes this.
post #5 of 11 (permalink) Old 04-30-2019, 06:39 PM
2008CL6's Avatar
Quoted: 6 Post(s)
I have disconnected both my batteries many times without doing this and nothing ever happened.
2008CL6 is offline
post #6 of 11 (permalink) Old 04-30-2019, 08:45 PM
PWidge's Avatar
Vehicle: 2007 S550
I can see the information now. Thank you for fixing it.
Like 2008CL6, I have never done this either, and I haven't had any problems. But, it's a simple enough process so I'll start doing it just to be safe.
PWidge is offline
post #7 of 11 (permalink) Old 04-30-2019, 10:36 PM Thread Starter
Quoted: 8 Post(s)
Nothing that appeared to have caused a long term effect happened on mine, but when I connect the ground in the trunk, the arc that is created indicates there is a fairly substantial quiescent draw on the entire system. Due to the fact I dont thing it is ever good to disconnect nd reconnect the battery, I have not put it through any kind of test. When disconnecting the rear battery, I generally remove the 15mm bolt first. The arc that happens when doing this indicates to me pretty substantial draw. I hope this procedure addresses this.
PWidge likes this.
post #8 of 11 (permalink) Old 05-01-2019, 02:09 AM
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Quoted: 108 Post(s)
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
This is quite helpful! AND that there is a procedure for something that would otherwise seem straightforward means (German thinking hat on) there must be a reason why! Thank you!
dlafever is online now
post #9 of 11 (permalink) Old 05-01-2019, 06:50 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 377 Post(s)
Note 2007-2009 221
https://workshop-manuals.com/mercede...ir/procedures/
konigstiger is offline
post #10 of 11 (permalink) Old 05-01-2019, 05:29 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 447 Post(s)
Thanks, TT! Added to the DIY & FAQs Electrical section.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
SBC Brake Flush Revisited (Again) - In Great Detail smyers The Discount Tire Direct Tire, Wheel, Brake & Suspension 8 05-11-2019 02:17 PM
Notes on the Coupe seat back lock system jal1224 W140 S-Class 10 05-09-2019 10:06 AM
Ignition Switch New fits many models sammywater For Sale/Wanted/Trade/Giveaway 0 10-24-2010 04:49 PM
S500, great car BUT need great help.... Seria W140 S-Class 25 10-05-2007 02:24 PM
Long sucess history Zé Bocaina G-Class 3 05-27-2005 01:19 PM
