Replace the Boot instead of whole Control Arm - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 03-03-2019, 02:16 PM Thread Starter
e39039's Avatar
Date registered: Mar 2019
Vehicle: 2012 S550 4Matic
Quoted: 2 Post(s)
Wink Replace the Boot instead of whole Control Arm
Hello,
I'm new here. I love Mercedes and DIY, so I record first video for DIY with Mercedes. Any comment are welcome.
My Mercedes S550 (W221) ball joint boot was broken. That's located at the front lower rear control arm. It is necessary to replace the entire control arm according to the requirements of Mercedes-Benz, (If don't replace the boot may lead to wear the ball joint with long time). So they only sell the entire control arm. , the cost should be $300 for the genuine control arm, plus $100 for an alignment, amount costs should be $400 exclude labor. I found the damaged boot timely, so I decided to look for an alternative boot and replace it. The boot cost only $12 from Amazon.
Here is the video
Name:	屏幕快照 2019-03-03 14.15.24.jpg
ID:	2493562   Click image for larger version
Name:	Boot replace.jpg
Skylaw likes this.
e39039 is offline
post #2 of 17 (permalink) Old 03-03-2019, 02:19 PM Thread Starter
e39039's Avatar
Quoted: 2 Post(s)
Here is the finished photo.
Name:	屏幕快照 2019-03-03 14.16.49.jpg
Skylaw likes this.
e39039 is offline
post #3 of 17 (permalink) Old 03-03-2019, 07:06 PM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 444 Post(s)
Thanks for letting us know, and welcome to the forum!
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
post #4 of 17 (permalink) Old 03-09-2019, 08:59 PM
Date registered: Jul 2015
Vehicle: 1997 C280
Quoted: 19 Post(s)
Hah! I did the exact same thing today after hearing a squeak from that same ball joint on the driver's side. I think the recent rains caused the issue. I was debating getting the replacement control arm on Amazon, but decided to take it apart this afternoon. My boot had disintegrated and no grease was in the ball joint, causing the squeaking. After throughly greasing the ball joint, I dug around in my garage and found a rubber brake pedal bellow to my '56 Oldsmobile, cut to size, reused the spring clamps and it works like a charm.
Now I find this post after the fact and see you can get the boot from Amazon. (Why didn't I think of that! Ugh!) Time to do the passenger side!
dlafever likes this.
Current Cars:
2008 Mercedes Benz S550
2003 Jaguar XJR
1970 Fiat 500L
1997 Mercedes Benz C280
1956 Oldsmobile 98
Former Cars:
2005 Ford Crown Victoria Police Interceptor
1997 Ford Crown Victoria Police Interceptor
1987 Alfa Romeo Milano
1986 Maserati 425
1969 Fiat 124 Spider
1971 Plymouth Duster
Jagpilot is offline
post #5 of 17 (permalink) Old 03-09-2019, 10:55 PM Thread Starter
e39039's Avatar
Quoted: 2 Post(s)
Thank you for replay 😄
e39039 is offline
post #6 of 17 (permalink) Old 03-09-2019, 11:22 PM Thread Starter
e39039's Avatar
Quoted: 2 Post(s)
Hey Jagpilot,
I was annoyed with the squeak of suspension for a long time since the car still covered by warranty, the dealer replaced the both of air strut, control arm, glued the bushing of sway bar etc. So I develop a habit to check the chassis constantly, lead to I found the broken boot timely. At first I was going to replace entire control arm, but the difficult is: tight the bolt and nut of control arm from front axle carrier " until the vehicle is in the ready-to-drive condition" is Mercedes required, that need four corner lift to support the wheel to drive condition. That is very difficult to me only have jack and stands. So if I can replace the boot I do not need to move the inside the bolt of control arm. That is why I'm seeking the replacement of the ball joint boot.
e39039 is offline
post #7 of 17 (permalink) Old 03-10-2019, 10:27 AM
Vehicle: 1997 C280
Quoted: 19 Post(s)
Originally Posted by e39039 View Post
Hey Jagpilot,
I agree. What I did not explain was that it took me an hour just to get the bolt of the ball joint back into the bolt hole after replacing the boot. I also only have jacks and jackstands. The issue was trying to line up the bolt with the hole and since the balljoint rotates, this makes it difficult. So to make the bolt line up (which was on the driver's side), I ended up having to use the spare tire jack at the front driver's side jack point, a jackstand under the front passenger suspension and my floor jack to push up on the front driver's brake disc. (I know, not a good idea. Should have removed the disc and jack up the hub. But it ended up okay.) This brought the bolt into the hole, and it required pushing back and forth until the bolt emerged straight from the hole. Then the nut used to pull the rest of the bolt through and tighten. That was a pain in the @$%#$! to line everything up!
Current Cars:
2003 Jaguar XJR
1970 Fiat 500L
1956 Oldsmobile 98
Former Cars:
1986 Maserati 425
Jagpilot is offline
post #8 of 17 (permalink) Old 03-10-2019, 10:48 PM Thread Starter
e39039's Avatar
Quoted: 2 Post(s)
Is that look like this process? I also tried many of times and method to align it up.
https://vimeo.com/user90483719/revie...954/2e877725a1
e39039 is offline
post #9 of 17 (permalink) Old 03-10-2019, 11:22 PM
Vehicle: 1997 C280
Quoted: 19 Post(s)
Yes, that is what worked for me. The key was to get the otherside wheel / tire up and not touch the ground, otherwise the steering rod will keep fighting you as you try to get the bolt in the hole. I did the driver's side balljoint by turning the steering wheel full right in order to access the balljoint. My other thoughts was to get a large C-clamp to get the bolt in, but I did not have one.
Current Cars:
2003 Jaguar XJR
1970 Fiat 500L
1956 Oldsmobile 98
Former Cars:
1986 Maserati 425
Jagpilot is offline
post #10 of 17 (permalink) Old 03-10-2019, 11:29 PM Thread Starter
e39039's Avatar
Quoted: 2 Post(s)
Got it. I lifted both side of front before I started the work, so I did not get too much difficult to align it up.
e39039 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W221 S-Class
DIY: Replace ball joint boots, front upper control arm jal1224 W140 S-Class 11 03-10-2018 04:50 AM
Advice on LH front wheel top control arm RJV W163 M-Class 9 08-18-2013 10:32 AM
cls500 replace control arm bushings and install camber adjustment bolts bevanet C219 CLS-Class 6 05-26-2013 06:18 PM
Auto transmission doesn't want to shift out of first bbpping W201 190-Class 12 01-11-2013 11:49 AM
test Jillian80 Test 5 06-09-2008 11:28 AM
